locked diff
I am wondering how to lock the diffs on a tamiya TL-01. I am kind of new. So pics will help alot thanks.
RE: locked diff
are you drifting.....why do you want to lock?
RE: locked diff
Even for drifting you should not need to lock them.
RE: locked diff
I used some plastic cement that comes in two parts n mix togethr. Just pulled out the gears and glued them. u kud jus pour the glue s*** in the whole thing but thas on u. Unless u want something removable i wud not suggest this method....
RE: locked diff
Search and though Shall Find !
I did a How to on How to Lock a TT-01/TL-01 Diff.. Use Blu-tac or Chewing gum lol. Cementing them is irreversible and not recommended.. http://www.rcuniverse.com/forum/m_4525622/tm.htm Follow your Manual instructions for access to Your Rear Diff Open it up, Cram Blu-Tac around the bevel gears inside the diff and reassemble |
RE: locked diff
you need to have the stock gears dont you?
Not speed tuned. because i bought my car second hand and the guy who had it before me raced it |
RE: locked diff
Speed tuned will be fine lock the Rear Diff and happy sliding..
RE: locked diff
thanx guys
locked my diffs today now i swing the back and keep it out. so mugh easier |
| All times are GMT -8. The time now is 06:57 PM. |
