ntc3 drift.
i need a basic list of everyhting i will need for my ntc3 to drift, aside from ABS tires, what other things can i do, im in alittle troulble im supposed to be running the drift series at my work in 3 months i get a full free car and what ever else i need to gett the program going any suggestions welcome except for tell me to sell the ntc3 and buy another car.
RE: ntc3 drift.
just hpi hard compound drift tires is all you will need.
RE: ntc3 drift.
well i was also thinking about some gear ratios, and i also have an 0s .12 tz s tuned and a .12 os tz eb mods. but those arent really torque engines or i can use a 18 tz eb mods i have and pull a compression ring off.
RE: ntc3 drift.
well... as everyone will probably tell you this. driftin isnt about speed , its all in control. and to have control, you need just the right amount of torque. so If I had to pick without doin research I would go with dat 18 or the 12 mods
RE: ntc3 drift.
wow, even with the stock set up its easy to pull some decent drifts, just some electrical tape on tires to test while i was braking it in, must admit easier then it seems and way easier then my electric for drift + the smoke looks to cool. haha
RE: ntc3 drift.
There is Two Different Styles of Drift, Broad, or Technical..
Nitro has Great difficulty pulling off the Technical Drift its Electric Cousins can do.. Broad Drift is achievable and Any Nitro motor will do. from a .12 through to .25.. Hard Compound Tyres is all that is needed |
RE: ntc3 drift.
now jw, will the yokomo ae86 sprinter body fit a nitro?
RE: ntc3 drift.
yokomo bodies are 190mm. Any body that you want to fit on a nitro must be 200mm
ORIGINAL: RickSDMF now jw, will the yokomo ae86 sprinter body fit a nitro? |
RE: ntc3 drift.
i know that but thanks, but on tower it says on specs its 200mm but thanks for clearing that up any ideas for bodies im open to anything, im just gonna use my saleen mustang body right now for practice and what ever body i get im going to airbrush and make some cool ass scheme, but yea i really would like to find a datsun or toyota body like a 70s 240z or 280, 510 what ever or a trueno or somehitng of that matter
RE: ntc3 drift.
most of those choices are 190mm check www.hpiracing.com for their 200 mm bodies
RE: ntc3 drift.
Yes unfortunately it is true.. All the really good classic Drift Shells are 190mm
Another reason to go electric lol ABC Hobby's do a 240Z or 280Z but only in 190mm Just to Prove I am not pulling Your leg.. http://www.abchobby.com/productimg/01bdy/big/fladyz.gif |
RE: ntc3 drift.
thinki could just swap all my arms for electric tc3 hardware? hehe just an idea.
RE: ntc3 drift.
hey, it might work!;)
RE: ntc3 drift.
well mad some advancements, got a imperza body, 26mm black te37 26mm super drift radials, and i found out the conversion to electric suspension will only be 30 to 50 bucks, and for the coolest hing drifting is about torque right? how about an os 4 stroke for onroad for 100 bucks wth carb and exhaust from my boss, coming out of his revo.
RE: ntc3 drift.
Torque Is what you need for those righ revs through the drifts.
RE: ntc3 drift.
http://i81.photobucket.com/albums/j2...1106061349.jpghttp://i81.photobucket.com/albums/j2...1060613512.jpg
thats it for now bone stock i jsut did a fast paint job on it, its a beater body. |
RE: ntc3 drift.
liking the shell dude!!.. what is it??..
RE: ntc3 drift.
free is what it was, haha a subaru wrc impreza
RE: ntc3 drift.
oh yea..lol, soz im not normally stupid...liking the desighn though. very cool.:D
RE: ntc3 drift.
well my super radial drift are almost burnt up so i tried pvc, awesome to drift with, if u like going 5 miles an hour and have no steering or brakes haha
RE: ntc3 drift.
Thats where Technical drift happens.. low speed.. and no control if you can master this your on your way to being a drift Pro!
RE: ntc3 drift.
well i cant say i have mastered it but with some mods to the abs i did, i can get some speed out of corner, and the technical drifts are a breeze, just gotta think out of the box on set up and mods to the abs tires.
RE: ntc3 drift.
just add some elctrical tape to the abs it will havea little more grip dut yet slide around
| All times are GMT -8. The time now is 05:10 PM. |
