Best source of PVC?
Hey guys I'm just wondering where most of you go to pick up the PVC pipe you use for your drift tyres? Is it just the local hardware store or do you go to a Plumbing Center or where? I had a look yesterday at Bunnings a big chain of hardware stores here in Australia and I could find anything close to the size I needed.
The inner diameter needs to be 50mm correct? |
RE: Best source of PVC?
its tires and yes 50mm is the right size you need to go to a store like a big big home improvment store like home depot
Yup you were spot on. I found 50mm PVC pipe at the Bunnings Warehouse (the equiv. to the US stores mentioned) here locally. Pitty its white but you cant have everything.
| All times are GMT -8. The time now is 11:54 PM. |
