RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   TT-01 R Conversion to Drift (https://www.rcuniverse.com/forum/rc-drifting-304/5281992-tt-01-r-conversion-drift.html)
Yub, yub, cmdr! 01-17-2007 08:42 PM
Hi, I am interested in a TT01 for drifting, but except for PVC tyres, what else would I need? (I am an experienced hobbyist so I have charger, batts, Tx, Rx, etc.)
SSJChar 01-17-2007 11:01 PM
RE: TT-01 R Conversion to Drift
nothing. all you need to change a standard 4wd kit to a drift kit is tires, which in your case is pvc, though abs is also an option if you can find any where you are.
Hyper 10s Sideways 01-17-2007 11:05 PM
you may wanna stiffen up the suspension a lil bit to m8 ;)
fl0PPsy 01-17-2007 11:08 PM
Oh I dont know about stiffening it. I think the TT-01R comes with springs etc that are just right for drifting.
infernox 01-18-2007 02:30 AM
r is more racing than drifting, get other springs, soft fron and stiff back.
and tighten up the diffs
fl0PPsy 01-18-2007 07:34 AM
R is more racing??? The TT-01R is the rally version.
infernox 01-18-2007 08:17 AM
tt01r is full hop up not rally!!!! better suiter for racing. otherwise it woulhv come with 60mm dampers etc.
wst50 01-18-2007 12:28 PM
ORIGINAL: Hyper 10s Sideways
PVC and ABS have so little grip that you need as much as you can get. Soften the shocks.
Yub, yub, cmdr! 01-18-2007 03:07 PM
Well, that's easy, because I have a lot of shock and diff oils from 1/8 nitro and 1/10 electric...
does the TT01R have ball or planetary diffs? Is it generally durable? Are there hopups I need for drifting besides those included?
Thanks for the help guys, the TT01 is cheap and I have electronics that I can put in it already.
sneff 01-18-2007 03:35 PM
Just buy the TT01 drift spec Subaru and you wont have to buy anything!!!
[img][/img]http://i35.photobucket.com/albums/d1...amiyadspec.jpg[img][/img]
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSG4&P=0
Auslide 01-18-2007 04:52 PM
Apart From Tyre Change: Nothing.
The TT-01R is indeed the Race Spec TT-01 with Ballbearings, Alloy Prop shaft and Oil Filled Shocks Standard..
There is Nothing You need to Change at all..
On a Stock TT-01, the only Changes you need to make it Drift is an Alloy propshaft and Wheel Bearing kit..
People have had a "Bouncing Issue" with a Stock TT-01, this isnt caused by the Shocks this is caused by the Stock 27T silvercan not producing Enough High RPM to keep the Polypipe Tyres rotating Quick enough.
Oil Shocks are not essential,they are a good upgrade but not essential..
Yub, yub, cmdr! 01-18-2007 05:01 PM
How about a TB-02? I just realized that I can get a much better deal on a TB-02... Thanks for the help, guys!
SSJChar 01-18-2007 05:18 PM
yes, a tb-02 is a good chassis. it has everything the tt-01 has(or atleast i'm pretty sure it does), plus more. it has a ball diff in the front and back and if you wanted to upgrade it in the future, i believe there are better hopups, or atleast from tamiya because it can use suspension parts from better chassis'. only problem with the tb02 is taht it has weak diff screws. they are direct swaps with the hpi diff screws, which are stronger and so just pick up a pack of hpi diff screws so taht you'll have some at hand when your tb02 diff screws brake.
Auslide 01-18-2007 05:22 PM
The TB-02 is a Plastic Version of the Race Bred TB-Ev03. A Brilliant Chassis..
Correct, it Does have the Weak Diff Screw problem..
The TT-01 is Just more user friendly..
Yub, yub, cmdr! 01-18-2007 08:09 PM
Alright, HPI diff screws are a cheap mod, so sounds like TB02 it is... (also going to get some nice fancy hopups)
Hopups I am going to get with purchase or immediately after:
1. Alu motor mount
2. HPI diff screws
3. a set of shock springs so I can swap those around
4. drift tires/ good looking chrome wheels, because it is going to be a street machine anyways.
5. alu propeller shaft
Spartan-Drifter 01-18-2007 11:08 PM
Batteries not included,hahahahaha.
infernox 01-18-2007 11:43 PM
go for the tt01r, its cheap and you get alot of hopups and a good motor.
just get some pe tyres and you a for away
Yub, yub, cmdr! 01-18-2007 11:46 PM
Thanks for the help, guys! TB02 it is! Because I can just take off the tyres and put on street tyres and handle well as a typical racer too! Sounds good... now time to find the best deal :-P
