RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   will this fit (https://www.rcuniverse.com/forum/rc-drifting-304/5368480-will-fit.html)
joeyblaze 02-04-2007 04:43 AM
will this fit
My question is would the Yokomo mirror/wiper, dsk brakes, and muffler kit fit on my TT-O1-R
i would assume the mirror and wipers will due they are glued and double side taped, not sure about the the mufflers and or the disk brakes
thanks guys
i730 02-04-2007 06:03 AM
RE: will this fit
yes they all will
the muffler kit goes on body too
but
you need yokomo wheels to use the yokomo disk brakes
dorkymk3 02-04-2007 02:29 PM
RE: will this fit
you dont need yokomo wheels for the disk brake. but one thing is you cant over tighten the nut or else you will crack the disk.
rcluke 02-04-2007 02:37 PM
RE: will this fit
ditch the disk brakes, get the neon's instead
Neon_guy 02-04-2007 04:22 PM
RE: will this fit
other rims are hard to fit over the yokomo brakes because the hex pattern is different from most other companies. Everything else is interchangable between bodies.
joeyblaze 02-04-2007 04:33 PM
RE: will this fit
how do you attach the muffs onto the body, yeah i think im going to get the mirror.wipper and muff kits, and dis the breaks
i noticed on some of the pics all you drifter there was no antenna,where do u guys keep it does it effect performance
neones where? i def want leds and what not .just not sure where to get them from, any links would be great
