Bodies
Hi i was wondering if a yokomo Drift body wuld fit
on a tamiya TT-01 because i hav the TT-01 but i luv the look of the yokomo drift pls wrt bk THNX |
RE: Bodies
any body will fit any chassis you just gotta drill holes
RE: Bodies
and write in English this isn't a mobile phone.. you can write full words..
Yes, Any body will fit.. just make sure your TT-01 has the Essentials before spilling out on an expensive body as it no point having a nice shell on a stock chassis |
RE: Bodies
that's true...not unless you have the right drill holes the car would on.Pics?
RE: Bodies
Not 100% true. Yes a Yoke body will fit on your chassis. But a 190mm body doesn't fit so well on a nitro (200mm) chassis. Also if you want a 200mm body on an electric chassis (190mm) you will have to buy offset wheels.
| All times are GMT -8. The time now is 05:19 AM. |
