Question About The Body
Hi , i just ordered my himoto nacsada and it comes with a 200mm body so im buying a 190mm body. Im not sure what rim/wheel to get for it my question is that does these rims/wheel fit the 190mm body? [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGMV7&P=7]Click[/link]
edit: if it helps this is the body : [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMRB9&P=7]Body[/link] |
RE: Question About The Body
It will fit just fine..
You just need to make your own body pole holes to suite the Chassis, this is best done once you have trimmed the shell out BUT before You have Painted it.. (Trim it out but DO NOT pull off the Over spray film.. Then Mask up and Spray (Yes HPI say Spray now Body hole and trim later but they are assuming your using a Sprint 2 where the Bodypole holes are pre-marked) I have found with the last 30 Shells that magnat has done, he now Trims first, Holes Next, Mask then Sprays, removes Masks and over spray film and Decals it His results are better then the way HPI do them as Trimming after spraying can lead to paint cracking.. As for the rims, they will look Great ! might be a bit sunken in but it should look fine.. |
I never trim after painting always before and I don't know why they reccomend that, it seems brainless to me.
yeah that is dumb, i always trip first, then line up and get the body holes ( i hate this part ) then i mask and paint
| All times are GMT -8. The time now is 11:17 AM. |
