Help, wierd TT-01 problem.
1 Attachment(s)
After I started drifting today, I realized that my motor was running way too hot. After a while, I noticed that no power was getting to the rear wheels and that a loud "tak tak tak" would be emmited under hard acceleration. After I opened up my car to check for the problem, I realized that my rear driveshaft link had shredded part of the place it was in, and that my 61T spur gear was missing some teeth. I also noticed that there was an abnormal amount of black dust all over my car. Now, my car is basically front wheel drive as no power is being put to the rear wheels. Look at this picture as well. HELP!
RE: Help, wierd TT-01 problem.
If your gear mesh isn't right between pinion & spur it will shread teeth.
yeah the drive train wasnt running smooth by the looks maybe when you built it?
the black dust is the spur shredding buy some new spurs and check what else needs replacing,make sure you lube it up good too m8. its a shame but it does happen [:o] dont let it put you off tho buddy stick with it[8D] |
ps just noticed have you got a bearing on the end of that propshaft piece?you may have taken it off for that piccy if you havent thats why its destroying it self m8[:o]
yeah there is one, it just got washed out by the flash of my phone camera.
omg my RC back on the road again today. Thank goodness! :D
that happened to me i fixed by new spur and pinion and a new diff case and gear!![sm=49_49.gif][sm=49_49.gif]
| All times are GMT -8. The time now is 05:46 AM. |
