RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   shock set-up (https://www.rcuniverse.com/forum/rc-drifting-304/6206357-shock-set-up.html)
d.k.v 08-07-2007 03:49 AM
shock set-up
What shock set up should on my shocks 4 drifting had/soft and should i have the ride hight high/low???
your help would be gr8!!
Rs43EVOman 08-07-2007 08:57 PM
RE: shock set-up
If your drifting on ABS then although youm might think a hard suspension will do best becuase drifting is all about little grip, right. In this case no you wanna run a soft suspension a common and good starting point is 20W oil all around with soft springs. Over time you can get slightly thinker oil and heavier springs to fine-tune it to your style and needs. I've been drifting for quite sometime, I have tried other set-ups and I find that to work best for me, so I stick with it.
d.k.v 08-08-2007 03:27 AM
RE: shock set-up
k thanks i might try that
Aries326 08-22-2007 01:11 AM
RE: shock set-up
Lower ride height helps with quicker transitions.
peetiewonder 08-22-2007 01:33 AM
RE: shock set-up
i found that softer springs up front gives the car more steering and better weight transfer for switch backs
Jordandarkmagic 08-22-2007 02:58 AM
RE: shock set-up
Use the soft springs for all four wheels but try and stiffen the rear springs by a little bit.
