RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Drift Tires (https://www.rcuniverse.com/forum/rc-drifting-304/6393901-drift-tires.html)
maxxdout 09-20-2007 05:40 PM
Drift Tires
Hello,
i have a spare set of rims that im not using now, and i was wondering, which size abs should i get? the rims are normal 1/10 touring size rims.
Thanks!!
Mattdg67 09-20-2007 05:44 PM
RE: Drift Tires
ORIGINAL: maxxdout
Hello,
Thanks!!
I don't have a clue what size. I would guess 2inch? Just bring a rim with you when you go buy some.
maxxdout 09-20-2007 05:47 PM
RE: Drift Tires
good idear ;) i just found my ruller and they are 2 inchers. Are there any special procedures to putting abs on rims? Would i still use regular tire glue? Ive heard something about a hetagun, but i no got!!!
Mattdg67 09-20-2007 05:58 PM
RE: Drift Tires
ORIGINAL: maxxdout
I say super glue for a nice strong hold.
Danju 09-20-2007 06:04 PM
RE: Drift Tires
i used hot glue to stick on my abs. after about a month its still holding up. im still waiting for it to come off.
maxxdout 09-20-2007 06:20 PM
RE: Drift Tires
haha, dont have any hot glue, so ill use tire/super glue.
Dman250 09-20-2007 06:57 PM
RE: Drift Tires
use gorilla glue or locktite powergrab...that stuff is strong enough to replace nails...superman couldnt remove it..
maxxdout 09-20-2007 08:13 PM
RE: Drift Tires
haha well, theres a little problem. If I ever want to remove em, using loctite wouldnt be good. THe strongest person i know is superman, so i will be screwed ;)
FireStriker 09-21-2007 01:51 AM
RE: Drift Tires
LOL, Just use super glue/ tire glue:D
peetiewonder 09-21-2007 12:06 PM
RE: Drift Tires
wrap your rims in e tape
///Toddy 09-21-2007 03:09 PM
RE: Drift Tires
yeah tapes are better!
Dman250 09-21-2007 03:57 PM
RE: Drift Tires
how long does ABS last because i kinda already put lock tite on my wheels so i guess im boned unless superman has been workin out.
GTB 09-21-2007 04:55 PM
RE: Drift Tires
NNNNOOOOOO!!!!![:@][:@][:@] Don't ever glue your ABS tires to your rims. ABS does not last for years. When they are completly worn, your never going to get them off. I see I have to start visiting this forum more often.:)
Dman250 09-21-2007 06:24 PM
RE: Drift Tires
like i said to late so hopefuly superman has been eating his wheaties
Danju 09-21-2007 09:37 PM
RE: Drift Tires
ORIGINAL: GTB
you can do that with hot glue. i can easily rip off the hot glue from the ABS. but for some magical reason, the glue will not come off while driving. i think hot gluing is the best way.
FireStriker 09-22-2007 01:27 AM
RE: Drift Tires
Tape give u a tight fit,
also you can use weather strippin!
Aries326 09-22-2007 05:09 AM
RE: Drift Tires
Here's all you need to know on cutting and mounting abs: http://www.drccentral.com/old/rcdrifttire.html
joeyblaze 09-24-2007 09:01 AM
RE: Drift Tires
yeah i second the E-tape.
just the wrap the center of the rims a few times with E tape then push the ABS over the rim, then step on it to mkae sure it fully locks one, and your good to go :)
maxxdout 09-24-2007 09:43 AM
RE: Drift Tires
thats what i did with my mini-t. I used some foam tape and e-tape and they locked pretty good. Since i didnt have any tires this weekend, i wne ton a rampage; i used only my rims, no tires, abs, etc, just rims!! they were my old rims, so i didnt care what happended to em. But man was thatt loud!!!!Worked well though.
maxxdout 09-24-2007 04:24 PM
RE: Drift Tires
Found some grey pvc pipe im gonna cut up in a bit. My mom's friend is an electrician and has tons of pipe he uses for wireing and stuff.
infernox 09-25-2007 05:18 AM
RE: Drift Tires
for attaching drift tyres to rims use weathering tape.
the foam tape with one side being sticky which you use to seal windows and doors against wind coming in.
works like a charm and the tire is easy to remove.
MANIQZ 09-25-2007 03:24 PM
RE: Drift Tires
I use electric tape around the rims and silicon glue around the inside of the rims. So if I need to change the rims, I can just scrape the silicon and plop the old abs, abs though is tough and can last a long time.
maxxdout 09-25-2007 03:54 PM
RE: Drift Tires
Just mounted em. They fit pretty snug, so just to reinforce them, i put a small bead of CA around the inner ring.
GTB 09-26-2007 03:57 PM
RE: Drift Tires
Well some rims will fit more snug than others.
GTB 09-26-2007 03:59 PM
RE: Drift Tires
