RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Possible Problem... (https://www.rcuniverse.com/forum/rc-drifting-304/6433407-possible-problem.html)
Drift Noob 09-30-2007 08:01 PM
Possible Problem...
Hi Guys,
I brought an RC Car last night, and when I go and pick it up the guy said the charger was stuffed. He said that he'd get it fixed and give the car to me for $260 instread of $305. Like, yay!
I asked him if I could see it running and he reckoned there was a little charge left in one of the batteries. So he plugs it in and presses the forward button, it goes forward at a slow pace, he presses it in reverse, and it shoots like a rocket.
Why on earth would reverse have more power than forawrds? Is it something wrong with the ESC or engine wiring (like, wrong way around or something)?
Thanks in advance.
ben805 09-30-2007 08:17 PM
RE: Possible Problem...
the ESC probably need to be program, some radio also let you reverse the throttle as well.
Drift Noob 09-30-2007 08:37 PM
ORIGINAL: ben805
Can you kinda... speak English? I'm not trying to offend you, I just couldn't understand what you said. Sorry.
zx360 09-30-2007 08:43 PM
my radio has a little slide open compartment that lets me adjust if when i pull the trigger its rev. and when i push the trigger its forward... see if there is something like that... or post up a picture....
Drift Noob 09-30-2007 08:47 PM
ORIGINAL: zx360
In fact it could actually be that, I know what you're talking about. My current RC car has that. But seriously, it was weird. It's got a proper Tamiya ESC (-TEU-101 BK) so I don't think it could stuff up like a china import or anything. But I guess anything could happen if it hasn't been treated and maintained carefully.
magnat 09-30-2007 09:25 PM
I think an ESC upgrade is needed. the TEU101BK ain't all that good..
Can you give us a run down on what you got, From Chassis to Batts
Drift Noob 09-30-2007 10:01 PM
ORIGINAL: magnat
Here's all the details on the car that is supplied on the auction:
-Nissan GT-R Z-tune skyline
-Based on the real z-tune street car
-2 540 motors
-locked diff for drifting
-speedi drift wheels
-Stock nismo rims and tyres
-Futaba T2PHKA transmitter
-Sanwa SRM 102 steering servo
-TEU-101 BK tamiya electronic speed contoller
-alluminum drive shaft (hop up)
-L.E.D front and rear lights
-Pro-Star 7.2volt Ni-Cad fast charger
-Tamiya RC1400SP 7.2 volt racing pack
-assorted spare parts
-instructions etc
High quality polycarbonate body realistically depicts the ultimate road car GT-R Z-tune
4WD shaft driven bathtub chassis with coil spring damped, 4-wheel independent double wishbone suspension and sealed front and rear differential gearbox
New plastic parts to reproduce wing, side mirrors, headlight case and tail-light case. Kit includes 4 LED lights to depict head and tail lights, (white headlights x 2, red tail-lights x 2).
Wide variety of tune-up parts available (sold separately) allowing the TT-01 to develop with your R/C experience and knowledge
C.A.R. 10-01-2007 05:05 AM
Yeah it's alright mate; as you suspected it's wired backwards. TEU-101's go really slowly backwards, but have fast progressive speed forwards. Don't worry about it, just re-wire it when you get it;)
Chris.
Drift Noob 10-01-2007 01:45 PM
ORIGINAL: C.A.R.
Chris.
Can anybody confirm this? Also, instructions on how to re-wire it would be great! Thanks
TIGER76 10-01-2007 03:32 PM
he probally means the wires (tamiya bullets) from esc to motor are the wrong way round making the reverse faster and the tamiya esc has a reset button on it which sets it back to standard;)
x2o 10-01-2007 04:03 PM
yeah, basically what I think is that the negative is in the positive and the positive is in the negative, thereby making it go backwards when it should go forward and forward when it should go backwards. All you have to do is unplug them and plug them back in proper.
Serpentd 10-01-2007 04:39 PM
I'm not too familiar with the ESC you have, but before you re-wire it, reset the ESC. if that doesn't work then maybe try the servo reversing on your throttle on the radio itself. I understand that it's not a servo that your reversing, but it might work in reversing your speedo. If all this fails then re-wire. Hope that all made sence. Good luck!;)
Drift Noob 10-01-2007 06:52 PM
Thanks! You guys (and gals if so) rock!
Drift Noob 10-04-2007 02:31 PM
Oh man... the noob that I brought it off still hasn't got back to me! The main reason why I brought it is to use it during the school holidays, their over in two days!!!! AAARGH!!
He's better be polishing it with his dog's tail or something cuze dude, I want to wrip his lights out!
On a nicer note, he fixed the ESC... :/
EDIT: I don't mean wrip the lights off the car, cuze they look sweeeeeet as!
