Bearing Set Dimensions
Hi guys,
I'm a budget guy and want to buy a bearing set for the TT-01, but don't want to spend that much on something I could get elsewhere for a lot cheaper. Cam anybody please give me the dimensions of the bearings (I know there is two types that come with the pack)... My dad works in the panelbeating industry and he works around these things every day, so he may possibly have higher quality bearings for cheaper. Can anybody please supply the following, please be as accurate as possible! Width: Outer diameter (length in mm from the outside edge to the opposite side edge): Inner Diameter (length in mm from the inner edge to the opposite side edge): I googled this question and couldn't find anything except for ebay measurements, and that wasn't for a TT-01. Thanks |
RE: Bearing Set Dimensions
Just to add, the dimensions may be in the manual.
5x11, and 8x12 i believe, just go to towerhobbies and check for the size of these bearing dude! you'll see them on the bearing set for TT01.
| All times are GMT -8. The time now is 02:33 AM. |
