tires-diffs-shocks (look i need your help please)
emmm for drifting how would i set the suspesion and ride hight ?and i herd somthing about locking the rear diff ? what does this do ? and is there any way of making some makeshift drift tires ?
all your help well be much appcated and how do i drift ? |
RE: tires-diffs-shocks
locking the rear diff will stop the car spinning out,susp is apersonal thing i suppose i go with low and hard for drifting.
For tyres you can wrap ur tryes in electric tape(black insulation stuff) or check ebay for pvc drift wheels they use the same hexes as most companies do. how do u drift?lol:D for quick try use the tape method to get started it takes a while to pick up just feather the throttle while turning once shes out wide start feathering the throttle to keep the drift going. get some video up when ur sorted bro ;) |
ah thank you very much can i put plactic pvc drain pipe over the weeks in stead of tape ? and are there any videos of drifting ?
omg that is pure rc drifting art
so in drifting is there anything i should do to a road car? its belt driven and is ballraced do i need fast sterring servos init or slow and shock oils what shall i run and will locking up the rear diff be better for drifting ?
RE: tires-diffs-shocks (look i need your help please)
so whats it like drifting ?
i bet theres nothing better then getting an awsome long drift am i right ? |
depends. some people like long endless drifts and others like technical drifts around S-turns
| All times are GMT -8. The time now is 12:37 PM. |
