RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   ta05-ifs (https://www.rcuniverse.com/forum/rc-drifting-304/6579648-ta05-ifs.html)
razor 2.o 11-04-2007 02:42 PM
ta05-ifs
how you all doing?good?
well,ihave a tt01 drifter and is not satisfied with it so i wanted to get something better,how about the ta05-ifs maziora 350-r?goog car?fast?durable?can it drift?
GTB 11-04-2007 09:32 PM
RE: ta05-ifs
I have the regular TA05, and its awsome, so the IFS must be Greatly Awsome!!:D:D:D
GTB 11-04-2007 09:35 PM
RE: ta05-ifs
fl0PPsy 11-05-2007 03:20 AM
RE: ta05-ifs
Yeah I dont know about the IFS. That front suspension config could be a bit of a pain.
razor 2.o 11-05-2007 04:55 AM
RE: ta05-ifs
yeah the front suspension might be a pain.so i should get the normal one to drift?
racenut18 11-05-2007 07:10 AM
RE: ta05-ifs
some says its a good drifter..
fl0PPsy 11-05-2007 04:01 PM
RE: ta05-ifs
Well if you can afford it go for the TA05MS. Its a TA05 with all the hop ups parts you could want.
Suprachrgd82 11-05-2007 04:13 PM
RE: ta05-ifs
ORIGINAL: fl0PPsy
The MS, as stated, will providea full assortment of hop-ups, so much it could even be considered a race chassis. This means tighter clearances, more adjustability, greater rigidity, precise handling, and lighter weight.
Though the IFS looks great, I have found that because there are more working parts in the system, it is prone to more slop. Instead of an upper and lower shock mount, you now have 4 pivot balls and a hinge. Each, having it's own imperfections, will add up to looser fitting final assemblies.
Most people upgrade, which will increase costs. A full build with quality parts (TRF, 3Racing, Square) will often cost more than the top shelp kit. In the long run, a simple purchase of the top-shelf car at the start will make driving more rewarding, and you forgo the upgrade process.
razor 2.o 11-06-2007 07:19 AM
RE: ta05-ifs
i couldnt find the TA05MS on tower hobbies (only site that i trust)
what should i get the ifs or the normal one
DriftProjectR 11-06-2007 10:27 AM
RE: ta05-ifs
ORIGINAL: razor 2.o
hpi sprint or look into a yokomo. :D
razor 2.o 11-06-2007 02:24 PM
RE: ta05-ifs
i kinda hate the hpi sprint
and i am afraid that my budget wont be enough for a yokomo since it comes as a chassis only and needs like a million things
so i will be staying withen the tamiya zone
but thnks for the suggest
Suprachrgd82 11-09-2007 07:17 PM
RE: ta05-ifs
http://www3.towerhobbies.com/cgi-bin...?&I=LXRXW0&P=7
