RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   HPI E10 or Tamyia TT-01???? (https://www.rcuniverse.com/forum/rc-drifting-304/6653774-hpi-e10-tamyia-tt-01-a.html)
keepontruckin 11-21-2007 09:53 AM
i want a good drifter, should i get a HPI E10 or a TT-01??
right now its between
http://www3.towerhobbies.com/cgi-bin...?&I=LXNUD2&P=0
http://www3.towerhobbies.com/cgi-bin...p?&I=LXTCR6&P=
HpiDrifter420 11-21-2007 09:56 AM
RE: HPI E10 or Tamyia TT-01????
out of the box the e10 is a better drifter. id onli get it if you dont want to upgrade it tho. alot of people are having problems putting more power to it b/c the driveline kant handle it. so im converting it to rally.
cbh148 11-21-2007 10:04 AM
If you're going to put ABS/PVC tires on, then there really isn't much of a difference between them performance wise. Both have oil shocks, plastic shaft drive (only TT-01 is upgradeable to aluminum), and I believe both have ball bearings. I know the tt-01d does
keepontruckin 11-21-2007 03:20 PM
yes i am going to put PVC on them, and i plan on getting very into electric drifting, and if they are so similar, i think ill go with the TT-01 the E10 looks cheap for some reason to me, but its probably only the body??
and the TT-01 has head/tail lights
HpiDrifter420 11-21-2007 03:24 PM
there both cheap...and onli certain tt01 kits/rtr come with lights
DriftProjectR 11-21-2007 05:34 PM
go with the tt01 since there are so many hop ups and support for it. the e10 is a new chassis and still has many kinks it needs to fix.
Infamous 11-21-2007 06:10 PM
I would say go with the TT-01 buddy. and i highly agree with DriftProjectR. they are not gonna stop making TT-01 parts anytime soon . but the e-10 has problems to be fixed. they may make a re-release of it or something with the problems fixed but who knows. for now i say TT-01:);)
magnat 11-21-2007 07:05 PM
Definately TT-01.. I am at wits end with my E10 and may send it off a 120ft water fall soon...
KrayzBIGmac 11-21-2007 07:33 PM
ORIGINAL: HpiDrifter420
From what I remember, people used to say the samething with the TT01. Nowadays, I see 7.5s in tt01s. So im sure HPI or people will figure out ways to make the E10 perform to its fullest. Just give it time. :D ;)
peetiewonder 11-21-2007 09:01 PM
tt01 ftw! i have one and its butter! it outdrifts my cyclone right now and it handles the 7.5 motor i have in it.
keepontruckin 11-22-2007 08:51 AM
sweet TT-01 it is!!
peetiewonder 11-22-2007 03:32 PM
a couple of must have upgrades for that car are the aluminum motor mount and shaft and ball bearings. makes the car a lot smoother.
Infamous 11-22-2007 08:56 PM
I just built my brothers TT-01 last nite and had all stock running gear apart from pvc tires and it drifted surprisingly well for out the box even with unlocked diffs:)
enjoy your TT-01 keepontruckin;)
keepontruckin 11-24-2007 09:55 PM
thanx
sounds sweet!!
