(Getting into Drifting) a couple of questions???
I just found the intrest to drift. I have messed around with a friends Tc3 and found out it is actually really hard. These are the questions I want answers for.
Should I drift electric or Nitro? What is the standerd setup for drifting? Tires and Such? What does it take to really become good at drifting? I am new so bear with me on this. Thanks |
RE: (Getting into Drifting) a couple of questions???
It will all be personal preference but here is my shortlist
1. Go Electric, Nitro will require a lot more maintenance/tinkering/set-up and cash. 2. The best basic set up would be 1:10 scale 4wd chassis, ABS or HPI T-Drift tyres, Soft suspension, Locked rear diff, semi locked front diff, a medium sized pinion so you get some punch with a bit of speed, once you get going you can look into motor/esc/chassis upgrades 3. Practice, practice, practice, initially spending time just controlling the car then moving into control round objects, linking drifts, track work, once you master this you will then be looking into set-up to create more speed with controlability. One of the keys to being a good drifter is not to fight the car, drifting should be fluid, flowing from one apex to the next with as little steering input as possible, throttle is the key, get sliding way before the corner and keep it going. The last thing to consider is are you a stick or wheel man, I started on sticks and found it very hard, when I switched to wheel things became a whole lot easier;) |
Thanks bro.. That's a lot of help.
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=007
check wat this guy is selling wheels and lights, wat a good deal |
hey a v imp ques...m usin a 3.2 cc engine rc car..should i go for a 2 wheel or a 4 wheel drive for good drifting???
AWD if you want to slide with control..
| All times are GMT -8. The time now is 04:00 PM. |
