your drift tires!
post comments on how yall like to make your drift tires. from scratch or pre bought. which do you prefer? post pics and how to's for guys and ladies who just need ideas thanks
RE: your drift tires!
I go down to lowes and buy a 2 ft piece of ABS plastic pipe(black). I then cut them 1mm wider than the width of my rims. 26mm rims, cut at 27mm. i glue them on the back side with CA glue
Well I go straight to the factory. I get the raw materials for abs piping and conduct laboratories in my science center and brew up 2" piping for drift tires...
C'mon...now. |
i used to one used yokomo single rings till i tried hpi t drifts
love the tdrifts now |
i like abs for the slower paced drifts and tamiya drift tires for the hi-speed drifts
I used to love ABS. Now I use Type-Ts for sessioning and competing. Abs is only ocassionaly now.;)
I also tried the new losi drift tires, they work pretty well imo
HPI T-Drift
go to the real drift tires man nothing compares to real drift tires you dont want dumb DIY stuff it's cheaper but ur car looks like crap
ive tried everything on my 2 yokomos. i use abs for slow drifting. groovy drift has a great section on how to make abs more controlable. it works great. i use yokmo single rings for high speed.
plain and simple |
Nothing slides like Home made ABS Tyres!!!
$4 for 32Tyres I cant Complain... |
i think if you drift on abs, it'll make you better. especially when you use regular drift tires
I go with scratchbuilt. at least I know where they come from and have ample access to all types of pipe.
I use HPI T-drifts, the drift WAY better than my ABS, and last twicw as long.:D
Yokomo Single Ring Drift Tires on one of my drifters, and ABS on my other. Waiting for a buddy of mine to hook me up with a set of HPI T Drifts.
ORIGINAL: GTB I use HPI T-drifts, the drift WAY better than my ABS, and last twicw as long.:D |
I made some ABS ones but I don't really like them. They work OK but they look stupid, I think. They look way too low profile, and they suck over craks or bumps. I much prefer my foam tires wrapped in electrical tape, they have more bite so it's easier to get it to snap back into shape when you let off the throttle. Also they are way smoother over road imperfections, the foam absorbs alot of the little disturbances. The profile looks right and it has more ground clearance too. The only down side is that the tape wears out after about 1 IB4200 pack. It ain't hard to tell when you need more tape, you go from little traction to foam in no time. I'd like to try some drift tires. Does anybody know, will these fit a TC3?
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRLD4&P=7]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRLD4&P=7[/link] |
i havnt drfted with it yet but i saw that poland spring waterbottles are about the width for fitting onto a tire i dont know if it would drift or not but ill try it out.
ORIGINAL: ana/RC/hy I made some ABS ones but I don't really like them. They work OK but they look stupid, I think. They look way too low profile, and they suck over craks or bumps. I much prefer my foam tires wrapped in electrical tape, they have more bite so it's easier to get it to snap back into shape when you let off the throttle. Also they are way smoother over road imperfections, the foam absorbs alot of the little disturbances. The profile looks right and it has more ground clearance too. The only down side is that the tape wears out after about 1 IB4200 pack. It ain't hard to tell when you need more tape, you go from little traction to foam in no time. I'd like to try some drift tires. Does anybody know, will these fit a TC3? [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRLD4&P=7]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRLD4&P=7[/link] |
Yeah I rounded them as much as I could. It's just very hard to find anywhere smooth around here. I don't like the way the suspension gets all of the shock with ABS, The foam takes alot of that out making for smoother drifts IMO, it just sucks re taping the tires all the time.
Umm I got some Drift Tires but I am not sure what kind of tires are they does anyone know?
http://i266.photobucket.com/albums/i...1/DSC02420.jpg http://i266.photobucket.com/albums/i...1/DSC02418.jpg The 2 lines with holes in the middle in the first picture are hard plastic. thanks |
I buy ABS pipe and cut the tires myself. Might pick up a set of T drifts.
what are some house held objests i can use to make drift tires?
ORIGINAL: ana/RC/hy Yeah I rounded them as much as I could. It's just very hard to find anywhere smooth around here. I don't like the way the suspension gets all of the shock with ABS, The foam takes alot of that out making for smoother drifts IMO, it just sucks re taping the tires all the time. |
ORIGINAL: FallenSnow Umm I got some Drift Tires but I am not sure what kind of tires are they does anyone know? http://i266.photobucket.com/albums/i...1/DSC02420.jpg http://i266.photobucket.com/albums/i...1/DSC02418.jpg The 2 lines with holes in the middle in the first picture are hard plastic. thanks |
o really? thanks, but are they good for drifting? and if the thing burned out do i just change the two lines in the middle?
For me, ABS and hard plastic tires like the T-Drifts don't have enough grip, especially
since I do a lot of high speed drifting and I drift with a Nitro TC3+, which has a lot more power than most electic cars. If you're running a nitro or a high powered electric, and/or you like the ability to do high speed drifts, or like the extra control from a little more grip, I'd recommend HPI Stage-D (slick) or A-Type(treaded). These tires seem more realistic also since they actually have some grip like real drift tires (which are actually sport street tires). If you're doing low speed drifting, or wanna slide reallly easily, then I'd recommend T-Drifts, they aren't that expensive, should be better than a home-made abs tire and they should still last a loong time. |
ORIGINAL: Corporeal ORIGINAL: GTB I use HPI T-drifts, the drift WAY better than my ABS, and last twicw as long.:D Rockit181 I have a mamba Max 5700 in my car, it keeps up with my friends TC3+ with a .18 in it. If you drift with a stock tc3 then I have more power than you. I run type t's cause then give my car low speed grip, but are still VERY controllable at high speeds. |
i like best my ABS over the stock tamiya drift tires...
| All times are GMT -8. The time now is 03:06 PM. |
