HELP ME!!!!
how do i get the tyres of the rims
RE: HELP ME!!!!
Buy new rims.. its easier
RE: HELP ME!!!!
no i just need to change my tyres, so how do i get them off
RE: HELP ME!!!!
Are they ABS or PVC or stock tyres?
RE: HELP ME!!!!
stock
RE: HELP ME!!!!
like rubber
if so cut as much of the tire off as you can and let the rims soak in acetone (sp?) for 24 hours they peel the remaining bit of tire off then let them soak for a further 24 hours then oyu are all ready to put new tires on |
RE: HELP ME!!!!
Just buy a New Set of rims for the New Tyres its a Waste to cut off perfectly good tyres... Just buy new rims and use them for the New Type T's your getting..
RE: HELP ME!!!!
i guess
dang now im ganna have to paint those rims black likei painted my other ones |
RE: HELP ME!!!!
I agree. I've tried a handful of times and it's a big pain in the neck. I've found if you are really careful when you first glue the tires, it's only slightly less annoying than, say, rebuilding a pullstart or trying to solder with one arm tied behind your back...:D
| All times are GMT -8. The time now is 11:45 PM. |
