Shock Setups?
Hi I was just wondering what spring setups you were running, I have soft springs in the rear and medium soft springs up front. Seems to be working pretty good so far. Although some more rear end traction would be good. How about you guys?
RE: Shock Setups?
if your looking for some more rear end traction. i would suggest putting medium-medium soft springs in the rear. this help in drifting when you go want to start a drift because the rear will break out easier. in the front run soft springs to get more steering and also it goes smoother over bumps.
i run soft-medium soft on my fronts and medium soft- to medium on mine. just me though. ;) |
| All times are GMT -8. The time now is 10:26 PM. |
