need some help!!!!
iv got a tc4 with carbon upper and lower chasis, and a 7.5 r. Got some hpi drift tires. Now mt problem i cant get the tie rod thingies all squared up it turns left really well but under full power with drift tires wont turn right so how the heck to i fix this iv tried everything nad im getting really mad! also how do i keep the battery from sliding out through the side?
RE: need some help!!!!
i used velcro to keep the battery on. as far as your setup, i would say just zero everything out, and if u have a setup station use it. also make sure ur shock spring loads and shock oil is the same, some can leak out and that can cause what you are talking about. the other thing that could be causing this is the torque steer from the 7.5 motor. good luck.
how do i zero everything out??? i cant get everything strait and true!
| All times are GMT -8. The time now is 03:55 PM. |
