Sprint 2 Drift Belts...
Hello, I have a Sprint 2 drift that eats rear belts like there's no tomorrow it appears to wear away the outer portion. I have been through the rear end every time the belt goes and have yet to have found any place that looks to be wearing the belt; nor have I found any debris in there. I've played with the little tension tabs on the drive shaft to no avail. Has anyone had a similar problem? Or does anyone have a suggestion?
THX in Advance, Doc |
RE: Sprint 2 Drift Belts...
1 Attachment(s)
did you do the diff case mods. i have a sprint2 that onli ate thru one rear belt ever. i shredded one did the modd and have yet to have another problem. just cut away the diff casing...heres a pic that shows where to cut...take the car apart to do it
Check if your motor isn't rubbing on your rear belt.. We had issues with some Motor Decals that would rub on the Belt...
Hey thanks for the help! I did the mod on the rear, Do you do it on the front too?
Also in regards to the motor decals, I've got a Castle CMS-6900KV Brushless in it, no labels on the case..... PS I picked up a TB-02 to add shaft drive to my drift fleet....... THX! ~Doc~ |
| All times are GMT -8. The time now is 01:53 PM. |
