best toe/camber setup for drifting...
tell us your best working setup for drift....:D
RE: best toe/camber setup for drifting...
Front's at 2.5deg, and the rear is zeroed out.
On my Sprint 2 I use ABS so I have mine on Zero all way round
POST A PIC OF HOW IT LOOKS WITH THE CAMBER:D
Camber: -1 on front 0 on back.
Toe in/ out: 0 Caster: 0 |
http://i81.photobucket.com/albums/j2...6/S5001587.jpgbefore pics of me stock toe in on my rtr sprint 2 sport drift
depending on the surface,
Front: 0° Rear: any where from 0°-1.5°(to get more bite) Front Toe: 0-+1° Rear Toe: 2-3° with abs i run 0° camber, with yokomo single rings i run 0° front and the 0-1.5° negative rear |
depends on your car and tire.
yoks i run 2 deg front and rear camber 0 toe in all around on my tt01 and 2 front 1 rear camber and 0 front, 2.5 rear toe in. type t i run 0-2 degrees camber same toe abs 0 all the way camber same toe |
| All times are GMT -8. The time now is 08:31 AM. |
