turning a TA-02 into a drifter
just bought a used TA-02 from the bay for my son...
he wants to drift it. it is currently a rally car. the suspension seems rather high. is this a problem? obviously ill slap some ABS tires on the wheels but what is best to lower the car? different suspension? or just cut the springs? thanks c |
RE: turning a TA-02 into a drifter
shorter springs should lower the car
Hi Mascac.
Have a look on the lower suspension arms and see if they have "droop adjusters" small grub screws that go through the arms and sit on the chassis. if so you can use those to reduce the ground clearence. failing that you will need shorter shockies. Unless you have some way of holding the suspension up, shorter springs will flop around when you lift the car up. Keep the rear firm to promote loosnes or oversteer and the front soft to prevent pushing or understeer and that should be a good starting point. Well thats my 2 cents worth. |
hhhhmmmm perhaps if i am upgrading the shocks to my TL01, i should put the stock TL01 shocks onto the ta02?
would that work? |
| All times are GMT -8. The time now is 02:08 AM. |
