RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   drift hop ups (https://www.rcuniverse.com/forum/rc-drifting-304/7941658-drift-hop-ups.html)
spadesjr 09-10-2008 08:37 PM
drift hop ups
what are some good hop ups to get to drift, i have a tt-01, i'm going to get some pvc and make drift tires, what else should i do? and where can i get the parts.
droppedgmc 09-10-2008 10:38 PM
RE: drift hop ups
you can get many hopups from your local hobby store or ebay. i suggest a 19t or 15t motor also.
spadesjr 09-11-2008 04:36 PM
RE: drift hop ups
what specific ones should i get. i'm planning on getting an aluminum shaft, and i want oil shocks but i can't find any non-expensive ones
bouledegum 11-22-2008 01:27 AM
RE: drift hop ups
the hop up you need on a TT01 depends on your budget
get the alu. dr. shaft and your all set
no need for a high speed engine cause drifting in done at low speed
the stock motor 540 is fine
you need good tires
get a 2 inch inside diametre PCV pipe
and fit them on any 26mm rims with two way tape and solvent
thats it
happy drifting
bouledegum
