RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   how???? (https://www.rcuniverse.com/forum/rc-drifting-304/8477361-how.html)
t-max97 02-14-2009 08:56 PM
how????
how can i make my nikko rc drift,i can do donuts with it.
SIRCC 02-15-2009 07:51 AM
RE: how????
make sure the diff's are lock and practice
TIGER76 02-15-2009 05:16 PM
RE: how????
Is it 4wd? like sircc says see if you can lock the diffs maybe not on a nikko ? If not try electrical tape over the tyres that always works a treat ;)
Gonna help to have awd though[:o]
t-max97 02-18-2009 03:51 PM
RE: how????
the diffs are locked its 2wd and it has slicks.
larryf333 02-18-2009 03:54 PM
RE: how????
I'm not sure a Nikko product will have enough power to drift, or maybe it has too much downforce on the rear.
larryf333 02-18-2009 03:57 PM
RE: how????
Another thing is, slicks have the most grip of any tires on dry surfaces, try the electrical tape over the tires and see if that helps. Drifters use a very hard rubber rear tire.
t-max97 03-01-2009 12:16 PM
RE: how????
Im trying to drift on slick lamanant floor so the tires are not a problem.i gess i will just have to but a drifter. anyone know of a realy cheap one?
t-max97 03-01-2009 05:02 PM
RE: how????
plz respond.
traxxaspede 03-01-2009 05:05 PM
RE: how????
try electrical tape! or even scotch tape would work, but it would wear out really quick.
t-max97 03-01-2009 07:12 PM
RE: how????
i did and it does not work.
larryf333 03-02-2009 08:19 AM
RE: how????
If you are trying to drift on laminate, you need something that is soft and slick. Foams might work for a little while, but once they get warmed up, they will grip. I don't know of anything else you can try to make a car drift on laminate. If you want something that's not too expensive, yet you can still repair and upgrade, I'd check into Tamiya products. I don't know if they have a drifter, but it can't hurt to look.
EDIT- Thought of something else you could try. Wrap some sort of material around the tires, like an old sock. You might be able to use a baby sock. This would eliminate any grip you have on a laminate floor.
str8.krooked 03-02-2009 11:43 AM
RE: how????
do a google or ebay search for TT-01 D. "D" stands for drift and it's a Tamiya product. It's not a great platform, but it's good for the price, and you can tune and upgrade to your liking.
t-max97 03-02-2009 03:48 PM
RE: how????
Okay thanks.:D
jybrd 03-02-2009 03:51 PM
RE: how????
I like my losi xxx-s as a drifter easy to do to dont buy the over priced drift xxx. just need new tires and tighten up the diffs in the front. and it comes with a fairly decent brushless system
t-max97 03-02-2009 07:10 PM
RE: how????
thanx:D
threezgood 03-03-2009 05:19 PM
RE: how????
as cra**y as it may sound the hpi e10 has really worked for me i have like it it comes r2r and its a fare price theres not a whole lot of upgrading you can do but there is some
