flux brushless problems!
okay so ive got a sprint 2 flux..its hesitating whenever i hit the throttle
RE: flux brushless problems!
cogging what batts are you using and what controller are you using
you probably need a higher mah batt...or you need to change the settings on the castle link if you have the stock flux esc because it is pulling to many amps and the battery can not keep up to the load current
| All times are GMT -8. The time now is 02:59 PM. |
