Could I plug this into my receiver?
Hey, do you guys know if I could plug this light kit into my Rustler VXL's receiver to power it?
http://www.horizonhobby.com/Products...rodID=LOSB9998
Thanks.
Thanks.
TX
Yes, but depending on your VXl ESC's BEC output voltage etc., (that's a mouthful) you may notice your LEDs are not fully bright. In that case you may want to use them with a separate battery.
What kind of battery would be preferable? I have a few 9V battery clips... would those provide enough power?
TX
I think you'll want 6 volts, depending all on what voltage the plug is supposed to be going into. I would think that since it's got a standard rx plug, that the system works off 6 volts?
That is what i am thinking too, Slo-V Flyer. More than this will burn the LEDs, or make them VERY bright for a little while until they burn. You can also use an Y-harness and power them directly from the receiverbattery, that means you are splitting the power before the receiver and leads it to both the LEDs and the receiver.
I agree. The best way you could go about figuring it out however, is finding out what the LED's are rated for, how many youll be running, whether youre running them in series or parallel, etc etc ad infinitum. All these things would determine how much power needs to be input to the system, but, also, the power itself can be limited just by going to your local electronics store and getting a resistor rated for what you need.
Banned
You "could," but that would depend on if you have a 3rd (open) port on your receiver - and chances are you stock receiver doesn't. But you could obtain a "Y-harness," and plug it into your servo port - and then plug your lights into one end of the Y and the servo into the other. People have been doing that for years.
Since it comes with a receiver plug, you can guarantee yourself it's designed to work plugging into the receiver - no need for a seperate battery.
