lipo fires
lipo fires
hey guys i have been into lipos for not long and today i accdently shorted my 3s pack after charging it. Itt was only shorted for less than a millisecond because i quickley disconencted the wires and placed the battery in a lipo safety bag fopr 30 mins. i inspected the pack and no signs of puffiness or swollen cell, looks the same. i have yet o use it because i would like know if its safe to still use the pack. thier are hardly burn marks on the shorted wires and indont want to throw the pack away. thanks
OH
RE: lipo fires
Check the voltages of the cells. If they're all ~4.2v (within a few hundredths, assuming you were balance charging) you're good to go.
There is an unnecessary amount of fear-mongering when it comes to LiPo batteries.
My Feedback: (8)
RE: lipo fires
I have shorted a 2s pack before. Left a very nasty burn on my thumb
But I still used it for along time with no ill effects.
I would check voltage on the cells and if everything seems good. I would run it.
Just my opinion
Just my opinion
RE: lipo fires
i was balance charging it when i finished i turned it off and the alligator clips i was using touched. I only charge to 4.16v per cell anyway. thanks for the heads up guys. im using a venom pro charger. so if you short a pack do the cells voltage go out of wack, so my balanced 4.15v cells can endup as 4.11v , 4.15v and 4.20v if that happens.
CA
RE: lipo fires
ORIGINAL: Haddi Taha
NY
RE: lipo fires
Everybody has the same opinion here, check the voltage, otherwise, you're fine. So many people out there scared about lipos......WHY? I have beat on mine so hard over the past few years and nothing. Even have a couple softpacks taking the same abuse. I think the problem is the videos out there showing them burnin. Problem is, not a single video shows you what the cause was. IMPROPER CHARGING/DAMAGED CELLS. Both of which are user error, not a function of the battery. Look at it this way, simple AA batteries, while they dont exactly explode, will crack open and cause really nasty acid burns.....again, only when charged way, way over limit, just like lipos.
RE: lipo fires
ORIGINAL: mc4798
Just my opinion
Just my opinion
Banned
RE: lipo fires
ORIGINAL: ThunderbirdJunkie
RE: lipo fires
yeah i tried it today and everything working fine. my venom pro charger today just wouldn't turn on somehow and every time i touched the alloy casing i would get zapped (like static shock). i have had only charged 6 times since the short circut and the battery and the leads were already disconnected from the charger when i shorted it so its not user error. i only bought it last week and it as broken down on me leaving me with 2 charger lipos and thats it. i'm really disapointed, a hate stick packs but till ive sent it back and got a nw one im stuck with a heavy, sluggish, almost dead nimh pack. i guess i have to be patient
My Feedback: (8)
RE: lipo fires
ORIGINAL: nitroade
Did you mean your thumb or the lipo?
ORIGINAL: mc4798
Just my opinion
Just my opinion
FL
RE: lipo fires
You REALLY have to make a big boo boo to get these things to burst into flames. That means shorting it out for longer than a "millisecond". It should be fine.
RE: lipo fires
ORIGINAL: Chuck Finley
Fear-mongering is a necessary evil when it comes to LiPo batteries [:@]
FL
RE: lipo fires
If only people would RTFM, in stead of ripping it from the box, throwing a brand new and barely charged lipo in, and rushing outside to run it around in circles in the street... then they wonder why their brand new toy quits working...
Next step, go online and post in every forum they can find, how Company X screwed them with a crappy product... [&:]
RE: lipo fires
ORIGINAL: FoamyVictim
One of the only reasons RTR's are kinda bad. People had to RTFM to put the kit together prior
RE: lipo fires
i have been using lipo for over 3 years now. never had one burst into flames.
i had one die, cause i left it in my plane plugged in. the ESC just drained the lipo. o volts per cell. but it didnt even swell.
i do have one 2s 5000mah pack that puffed just alittle. i think i had my truck overgeared. i still use the lipo, i just check that the cells are properly balanced before i use it.
MT
RE: lipo fires
FL
RE: lipo fires
ORIGINAL: Brainanator
I'm so confused reading this post
"I somehow fried my charger"
RE: lipo fires
i was expecting fire, but nothing could have prepared me for how much smoke came out of there!
[youtube]http://www.youtube.com/watch?v=5rjesXo7GtQ[/youtube]
