whats a good esc/motor combo for the bandit
i just bought the traxxas bandit wit the xl-5 an the titan 12t motor its the waterproof edition so its brushless ready an im now on my third motor in about 12 cycles so im done wit the titan an ready for brushless but im new so i dont know what im lookin for an i only have about 60-80 dollars so im lookin for the best combo i could get for that
RE: whats a good esc/motor combo for the bandit
Get yourself a decent 15 turn brushed motor and a smaller pinion and you'll be good to got. I personally like the Speed Gems motors but the brushed stuff is getting harder to find. Stay away from FireBall.
SK, BANGLADESH
ORIGINAL: hpiracr28
save up around $150 and get the vxl system. best bang for your buck.
for $100 the sidewinder V2 or SCT has more power on 2S, and there's plenty of chinese type stuff that people like well for $80ish
the VXL is overpriced and under featured, I've had a VXL system and it's nice, but it's not any better than the rest of the stuff that's 50-70 bucks cheaper
well i've never really done research on other setups, i just thought this would be good for his bandit since i have it in mine. plus im not fond of the cheap foreign made stuff like on hobbyking. never kno of the quality till you risk $100
SK, BANGLADESH
there's no quality issue with Castle, they have tech support in the USA just like traxxas does and they're $50 cheaper than the VXL setup
again, the VXL is a good setup, but it's expensive for what you get much like everything traxxas does
well i will admit traxxas does have some pricey items. nothing i will ever purchase or need. i have heard many things about castle, just never really looked them up. but if he's only got like $80, he should get something with a good name brand. probably not some off brand. but then again this is just my opinion. name brand thats very well known vs. off brand hidden in the fog.... i like the features of the vxl personally. but for his budget prob a cheap castle system
Speaks for itself...
Save up a little and you will love this combo...
SK, BANGLADESH
ORIGINAL: hpiracr28
with the castle stuff you can adjust throttle and brake curves individually, you can adjust the amount of drag brake, you can set punch control/torque control to act like a basic traction control system for the RC. you can lock out reverse as well, and it's lipo cutoff is adjustable
much more adjustability than the 3 mode VXL, (reverse off, reverse on, training mode)
I definitely agree with going to the castle setup. I had the VXL and fried the esc so i switched to the cheaper Castle sidewinder as per several recommendations from this forum and am so glad I did. I didnt think the tuning was going to be a big deal for me since I had never played around with it before, probably because I couldnt with the VXL, but it is quite nice to be able to adjust the throttle curve and the amount of braking seperately as well as all the other things you can adjust on it. Well worth the money saved since you actually gain functions instead of lose them.
ORIGINAL: hpiracr28
well ive decided on the castle sidwinder but now im not sure what motor to get an what the best gearing would b right now i only have a 26 an 31 pinion an a 76 spur if i have to ill get more gears but without chaingin gear i dont know what motor to get (4600kv,5700kv,or 6900kv)
SK, BANGLADESH
I'd look at the SCT version (3800kv), 4600, and 5700 in that order
the SCT version comes with a beast of a motor compared to the CMS36 motors (4600,5700)
and I also like to think about what else you may throw the combo in later, the lower KV the larger vehicle you can throw it in later. if you get the SCT 3800, or 4600 you can throw it in a short course truck later if you want (if you go 3800, you can even throw it in a 4wd sct and still have great power)
the 6900 is going to be too high strung to go in much of anything other than a buggy or a TC so I'd skip that option
SK, BANGLADESH
ORIGINAL: hydru85
ya but the sct is a short corse truck setup i have a buggy that wont matter
I still recommend the Velineon motor just not the esc. Only motor I've tried out though and have had no issues so I'm kind of biased towards it. Tons of torque and speed, more then you need thats for sure, I couldn't keep my front tires on the ground for the first few batteries till I learned how to handle the power. Running a 3s with my setup probably helps that problem though
you need to stop buying cheepo booboo motors.. save a little more money, and get a castle creations motor and speed control or simply a vxl system.... i have the associated rc10b4 buggy/ or 100 mph+ street raceing truggy, which is pretty much, the same size and everything as the bandit.. i spent a little over $2,000 and built it from scratch buying every upgrade part that you can.. it's now nothing but aluminum, titanium harded steel or carbon, oh and of coarse copper for the liquid cooled radiator i'm adding so the motor will nevr over heat.. you might want to invest in a ryobi heat lazer.. to quickly check your temp after every run. it is the cheapest and best investment for any electric rc.. you can get one at lowes or home depot..
SK, BANGLADESH
ORIGINAL: Captain Rusty
SK, BANGLADESH
ORIGINAL: Trick Icarus
I'd also like to see some pictures of the harded steel parts you used
OH
A: Get the Castle Sidewinder SCT system. You can gear it to the moon and it runs cool.
B: A $2,000 B4 that goes 100 mph...now ThunderbirdJunkie has heard EVERYTHING.
My Feedback: (8)
Castle system comes with a good warranty. Its a good thing otherwise it would be the biggest POS unleashed on the public since the XBOX 360 .
2 grand B4 ? Sombody needs to wake Alice .
ORIGINAL: ThunderbirdJunkie
Did you hear about how a chimpanze nabbed some dudes credit card and ordered a traxxas slash 2wd off of the internet.
then when he received it he turned it into the fastest and best handling sct on the market and wet on to beat durangos and ofnas and win the worlds and rc x games?<meta charset="utf-8">
he even created his own electronics!
</meta>
