RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
HELP no response!!
Old 05-03-2011, 12:56 PM
mrswift
Default HELP no response!!
Hi, I have a brushless ansmann vapor rtr, I have had it running just fine, then i left it alone for three months and it does not work. I have tried all the basic stuff, changing/charging batteries etc. The problem is when I switch on the car it makes the usual beeping noise and the led's are on ok, but when I switch on the transmitter I get no response at all, before when I switched on the transmitter it would set the wheels straight? it seems as though there is no communication between the transmitter and receiver?? But, if I hold the aerial of the transmitter near the car and wave it around the steering servo gets 'twitchy' I have no clue what to do?? Any ideas will be appreciated. Thanx.
Old 05-03-2011, 01:25 PM
Karontu
Karontu's Avatar
Default RE: HELP no response!!
turn on your radio then your car, you should always do it in this order.
also are you using am/fm or 2.4ghz?
Old 05-03-2011, 02:05 PM
mrswift
I have tried that, makes no difference, no response still?
the ansmann transmiter is the W3 (not the W3.1) it uses 40mhz and the crystal says 53 on both the tx and rx, nothing has changed since it was last used other than it was sat for a few months?
Old 05-03-2011, 02:06 PM
Karontu
Karontu's Avatar
are you using 2.4, am, or fm?
Old 05-03-2011, 02:13 PM
mrswift
FM 40mhz
Old 05-03-2011, 02:16 PM
Karontu
Karontu's Avatar
check for tears in the recievers antennae
Old 05-03-2011, 02:24 PM
mrswift
alls good mate, it is as new in that sense, no tears, rips etc. have just had a good look to make sure
Old 05-03-2011, 04:43 PM
Captain Rusty
Have you tried reprogramming it?
Old 05-03-2011, 10:28 PM
Haddi Taha
Haddi Taha's Avatar
i heard sometimes crystals go bad after a while but idk.
Its definetly a radio/reciever issue
Old 05-04-2011, 06:17 AM
mrswift
how would you go about reprogramming an esc?
Old 05-04-2011, 07:03 AM
mrswift
Hi, I have just changed the receiver for one out of an older ansmann car and whilst it still does not respond, it will fully respond when I touch the bare wire from the reveiver antenna to the transmitter aerial, as soon as i part them it does not respond. Any help appreciated. Thanx.
Old 05-04-2011, 07:06 AM
sloppyG
are you using a NIMH pack?
after a few months it may be shot
Old 05-04-2011, 01:12 PM
mrswift
No mate, 2's lipo 5000, definitely nothing wrong with the lipo's!
Old 05-04-2011, 01:51 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
does the radio use crystals? if so are they good or the same #?
Old 05-04-2011, 01:55 PM
mrswift
same number, appear to be ok, at least when i touch the bare rx antenna to the tx aerial?
Old 05-05-2011, 02:24 AM
mazdaprotege4
My Feedback: (32)
Did you leave your battery plugged in while you stored it?
Old 05-05-2011, 01:24 PM
mrswift
I cant remember, possibly, why would this matter after just a few months, (I know it is not recommended)?? surely it would do no harm to the esc, tx or rx??
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
