Adjustable slipper clutch assembly slipping too much!!
Hi, my Adjustable slipper clutch assembly of my thunder tiger phoenix st2 is slipping way to much.
When I acelerate and when I drive I can hear it slip.
I have tighten the nut keeping the assembley in place as tight as I can but no luck. What part in the assembley could have weared out? Or is there a trick to stop it from slipping too much?
RE: Adjustable slipper clutch assembly slipping too much!!
How do I identify the slipper pads? The manual does not say anything there is only a Clutch disk, Diff drive ring, Slipper ring and a torque hub.
I am not sure to which one you are referring to.
