what C rate battery should get
Hi there I am thinking of getting a castle motor, the 4600kv 4 pole version runningon 3s what C rate should i use at the moment truggy allows turnigy 3000mah 3s size. Any bigger and rubs on drive cup they are 20cis that high enough.
p.s does anyone know how to upload pics cos i have tried but no luck
thanks filly
thanks filly
RE: what C rate battery should get
You want to use a lipo with a "C" rating of 25 or higher.
I use www.photobucket.com to host my pictures so that I can then post them to the internet.
IL
To upload pics, use the "Reply" icon next to the message you are replying to (instead of the "quick reply" box at the bottom when you are reading all the posts).
Then, in "Reply" mode, you'll see a "Click here to upload images and files" link under the text box. Use that.
yeah 20c is to low for that motor combo on 3s, Buy a Turnigy Nano-tech 35c-70c bursts I own one on 2s and my truck flys like my cheap zippy 3s 20c, I cant imagine there 3s
PA
I personally like to stick to 30c and higher since they only cost a few bucks more then 20c. but you'll want the highest c-rate you can afford.
