RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
onyx bl system...??
Old 03-23-2013, 04:22 PM
trx1
Default onyx bl system...??
i just bought a onyx 3930 bl system....have a few??'s
do i have to run lipo??
will it run on a speedpack3300 nimh??
how do i turn off the LVC on it so i can run nimh packs??
Old 03-23-2013, 04:36 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Default RE: onyx bl system...??
ORIGINAL: trx1
ouch, green type hurts the eyes!
brushless systems can run on a nimh battery. But its like running a drag car on pump gas. you will only get 80% of what that motor can do. It will be faster than the brushed system you had, but up to a 2s lipo and it will be much better.
did your system come with a manual? some can be programed via the radio (tones and beeps) some can link to a computer and others can have optional program card.(my fav)
Old 03-24-2013, 07:28 PM
lone_wheeler
At last check, the onyx bl systems are made by castle, so their programming card or usb interface should allow you to set your esc up the way you want it.
And yes, lipos are better than nimh for brushless systems. Once I get better at control and tighten my steering up i'm getting a 2S lipo pack.
Old 03-26-2013, 08:27 AM
EXT2Rob
EXT2Rob's Avatar
Yes, you can run NiMhs on a brushless system, won't hurt the system, but it WILL hurt the battery.  NiMhs just aren't designed to dump current like LiPos can, and the NiMh battery will get hot. Heat is bad. It will eventually kill the pack.  But, I suppose you might as well use them until they're dead (unless you have a friend who's still running NiMhs).
Old 03-26-2013, 08:33 AM
redfisher1974
redfisher1974's Avatar
ORIGINAL: trx1
$15 for programming card... [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCACX&P=M]LOOKY HERE[/link]
Old 03-26-2013, 09:36 AM
trx1
ok,2nd ?'s
1. ive seen that lipos need special chargeres..am i right??
2. puffing...??
3. HARDvsSOFT...which is better??
4. ive heard these will run then just stop...whats with that??
5. storage...what do i need??
Old 03-26-2013, 09:56 AM
redfisher1974
ORIGINAL: trx1
ok,2nd ?'s
2. puffing...??
Google "LIPO UNIVERSITY" will tell you what you need to know.
Old 03-26-2013, 12:50 PM
trx1
didnt tell me anything i wanted to know...
Old 03-26-2013, 12:57 PM
redfisher1974
You're joking right?
Old 03-26-2013, 01:19 PM
trx1
graphs and charts dont help me....i did find out for my lhs a few things tho
Old 03-26-2013, 02:15 PM
redfisher1974
ORIGINAL: trx1
You'll be a pro in no time my friend.
Old 03-27-2013, 10:02 AM
EXT2Rob
EXT2Rob's Avatar
ORIGINAL: trx1
ok,2nd ?'s
2. puffing...??
1. Yes, you need a charger specificly designed for LiPos. http://www.hobbypartz.com/73p-ac680-accharger.html
2. Puffing is an indicator that the battery is being stressed. Either being charged too fast, or drained too fast, than it was designed to be. Be sure to get a battery that can handle the Amp draw the motor system wants. Get at least a LiPo rated at 40C continuous.
3. Hard case, in cars, always.
4. LiPos should never be drained below 3.0V per cell. That's why BL systems have a setting for "LiPo Cut-Off" which should be set to 3.2V per cell. When the ESC detects the battery voltage, under load, has dropped below the set point, it cuts the power to the motor.
5. Storage? Not sure of your question, but, LiPos do not like to be left sitting fully charged or discharged. They like to "rest" at 3.86V per cell. LiPo chargers have a "Storage" mode just for this. As for the horror stories you may have heard about spontanious combustion with LiPos: BAH! As long as you don't damage them physically (hence, Hard Cases) and don't do something stupid like over-charge/-discharge don't worry about it. Iwouldn't even waste my money on so-called "LiPo charging bags".
Old 03-27-2013, 01:51 PM
crazy nick
My Feedback: (29)
crazy nick's Avatar
ORIGINAL: lone_wheeler
False, the element was made by castle, the onyx is made by hobbywing
Old 03-27-2013, 03:30 PM
ElectricGuy007
Im getting one of these for my 2wd Corr truck. Might as well get the 2-pole version.
I have Lipo packs thou, so not wanting to run nimh anymore really.
Old 03-27-2013, 05:08 PM
trx1
DTXC3164 Onyx 1/10 Scale 3930kV Brushless System
thats the one i have...so where do i start with batteries/chargers??
Old 03-28-2013, 07:03 AM
EXT2Rob
EXT2Rob's Avatar
5. Storage? Not sure of your question, but, LiPos do not like to be left sitting fully charged or discharged. They like to "rest" at 3.86V per cell. LiPo chargers have a "Storage" mode just for this.  As for the horror stories you may have heard about spontanious combustion with LiPos:  BAH! As long as you don't damage them physically (hence, Hard Cases) and don't do something stupid like over-charge/-discharge don't worry about it. I wouldn't even waste my money on so-called "LiPo charging bags".
Old 03-29-2013, 07:07 PM
trx1
what about the onyx brand?? my lhs carries these.
Old 03-30-2013, 07:32 AM
EXT2Rob
EXT2Rob's Avatar
They're probably good. Just get a decent C-rating.  How much are they at your LHS, tho?  I'd bet over $60.  You could get a Gens Ace brand $20 cheaper at HobbyPartz.
Old 03-30-2013, 07:37 AM
redfisher1974
Or a zippy even cheaper at HobbyKing.
Old 04-02-2013, 01:34 AM
trx1
dont know if i wanna keep this or not!
seems like i cant run nimh on it.
this is why im not a fan of bl systems.
only one ive enjoyed is the vxl system.
it can handle nimh!
Old 04-02-2013, 02:48 PM
ElectricGuy007
Once you go Lipo you'll forget all about NIMH. I have ditched all my nimh packs for Lipo packs.
I wouldnt even complain, because all you gotta do is buy a lipo and a lipo charger.
Old 04-02-2013, 03:06 PM
trx1
and i hear those arnt cheap either
Old 04-02-2013, 03:34 PM
redfisher1974
They are if you get them from Hobbyking.
Old 04-04-2013, 12:01 PM
trx1
so is HK in the USA??
Old 04-04-2013, 01:01 PM
redfisher1974
They are from china but they have a warehouse in the USA.
