Need some help...restoring a 1991 JRX2
I need to upgrade the radio, esc,motor and battery. My question is can the gears that came with it handle brushless power? If it can, any suggestions on these things I need? Thank you in advance
Moderator
The system I'm mentioning below is a very mild brushless system, and that car could handle it fine.
Radio; http://www.hobbyking.com/hobbyking/s...arehouse_.html
ESC; http://www.hobbyking.com/hobbyking/s...arehouse_.html
Motor; http://www.amainhobbies.com/product_...ed-Timing-175R
Battery; http://www.hobbyking.com/hobbyking/s...arehouse_.html
CA
Also if you do put a Brushless system in you mite want to up grade your trans with a hyda drive sliper clutch system it'll save your trans from any hard shocks or Hard starts
