Need help with savox servo
hi i recently purchased a savox 1267sg servo and put it in my dex210. the servo works fine as a raced with it last night but it is not quick at all, it says its 0.095 seconds but it seems more like 0.20. does anyone know how i can change it to go faster or what the problem is. thanks Jack
That servo is a High Voltage servo. If you are running it off your receiver, you are not getting the servo's full capability. Other than that, I don't know anything about High Voltage servos, and what you need to do to use them. My LHS guy doesn't like Savox servos. Says they draw way too much current, they cause ESC BECs to "brown-out", and they're way too expensive for what you get. Stick with HiTec.
