RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Lee's Axial EXO Terra Buggy build thread
Old 02-08-2014, 08:40 AM
lee172
lee172's Avatar
Default Lee's Axial EXO Terra Buggy build thread
I've had this for a while, so it's about time I did it justice...!
Treated it to a Castle SCT brushless system and some hop ups..
Left to right: aluminium/graphite steering upgrade, rear chassis brace, motor mount, front shock tower and rear skid plates, I also bought the green body panel set but can't find it..
ID:	1966522   Click image for larger version
Old 02-08-2014, 09:23 AM
lee172
lee172's Avatar
Some neat box art.. not quite sure about 'racers only'...
All the parts laid out..
Wheels and tyres glued up.. (turned out nice, as I usually get glue everywhere!)
ID:	1966537   Click image for larger version
ID:	1966538   Click image for larger version
ID:	1966539   Click image for larger version
Old 02-08-2014, 10:12 AM
lee172
lee172's Avatar
Sealed diffs being built (they are sealed in three places) either side of the output shaft and also between the ring gear and diff case..
Heavy weight oil and finished diff..
ID:	1966543   Click image for larger version
ID:	1966544   Click image for larger version
Old 02-08-2014, 01:34 PM
lee172
lee172's Avatar
Grease is the same colour as the hop ups!
Deviated from the instructions and built a shock..
Front end coming along nicely..
ID:	1966594   Click image for larger version
ID:	1966595   Click image for larger version
Old 02-08-2014, 03:15 PM
Eman77
Eman77's Avatar
Very cool so far, nice pics!
Old 02-08-2014, 04:25 PM
DarkFire989
DarkFire989's Avatar
Pretty sweeeeeeeeeet! Looks awesome.
Old 02-09-2014, 08:29 AM
lee172
lee172's Avatar
I keep seeing these parts... a bit random!
Rear arms finished..
Centre diff oil, twice the weight of the other diff oil.. Leaked all inside the bag so I threw it away (that stuff is too messy!)
Showing the seal on the ring gear..
ID:	1966893   Click image for larger version
ID:	1966894   Click image for larger version
ID:	1966895   Click image for larger version
Old 02-09-2014, 08:33 AM
lee172
lee172's Avatar
Found some even heavier oil and used that.. centre diff complete..
Front end mounted on the chassis..
Motor mount comparison.. (they look similar but the upgrade holds the motor in place by 2x machine screws, the standard mount uses 1x grub screw..)
Centre diff and motor mount installed..
ID:	1966897   Click image for larger version
ID:	1966898   Click image for larger version
ID:	1966899   Click image for larger version
Old 02-09-2014, 08:37 AM
lee172
lee172's Avatar
Rear end and chassis brace installed..
Castle SCT motor, standard 540 size but this thing is heavy!!
Motor installed..
ID:	1966901   Click image for larger version
ID:	1966902   Click image for larger version
Old 02-10-2014, 08:08 PM
Lunchboxer
Lunchboxer's Avatar
Looks good so far! At first I thought it would be some sort of crawler type setup based on the looks.. but looks like it is a performance buggy.. !
Old 02-14-2014, 01:10 PM
lee172
lee172's Avatar
Nice metal geared servo.. (Ni-Cd use only..!)
Upgrade steering link vs standard..
In the end I had to ditch the carbon bar (as you'll notice its a few mm wider) as it was catching the front bulkhead very slightly.. bit of a school-boy error by STRC..
All fixed in place..
ID:	1968521   Click image for larger version
ID:	1968522   Click image for larger version
ID:	1968523   Click image for larger version
Old 02-14-2014, 02:23 PM
lee172
lee172's Avatar
Servo mounted (but not centred yet)..
Got bored of waiting for the batteries to charge so I put the wheels on.. (sat the chassis on the servo box for realistic ground clearance)..
ID:	1968526   Click image for larger version
Old 02-14-2014, 03:00 PM
Eman77
Eman77's Avatar
Very nice. I like the green theme.
Old 02-14-2014, 03:17 PM
lee172
lee172's Avatar
Gotta keep it all coordinated!
Servo centred and connected..
Battery housing attached..
ESC holder/ESC mounted..
ID:	1968532   Click image for larger version
ID:	1968537   Click image for larger version
Old 02-15-2014, 10:22 AM
lee172
lee172's Avatar
Waterproof receiver box fitted, ESC connectors 'Deaned' and cable tidies attached..
Front bash guard fitted..
Cage started..
Cage finished!!
Cage roughly attached.. (need to sort a lot of details before it can be attached properly)..
ID:	1968693   Click image for larger version
ID:	1968694   Click image for larger version
ID:	1968695   Click image for larger version
ID:	1968696   Click image for larger version
Old 02-18-2014, 11:32 AM
Eman77
Eman77's Avatar
The cage is neat. But I wonder how painful it will make it to get to things.
Old 02-18-2014, 12:29 PM
zackS30
zackS30's Avatar
Its hard to get to the battery from the side and to get to the esc and motor and servo u have to take the chage back off. Its annoying at first but it gets easier.
Good lookin build so far btw, I love my exo!
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
