RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
OFNA lx2e rtr help!
Old 09-06-2014, 04:44 AM
mr jimmm
Default OFNA lx2e rtr help!
hi, i just got an OFNA lx2e rtr but i cant get it working, evryting pluged in charged up etc.
When i turn the esc on i get a slow flashing green light, the steering is working but not the throttle!
Help please!!!
Old 09-06-2014, 07:31 AM
cumminspower5.9
cumminspower5.9's Avatar
Read the manual on how to bind it. Should be the issue.
Old 09-06-2014, 08:12 AM
mr jimmm
I have tried to rebind it, but when i do the there is no light on the receiver compared to the normal green light on it
Old 09-06-2014, 08:49 AM
mr jimmm
I have also tried a different transmitter and receriver
Old 09-06-2014, 02:43 PM
collector1231
Moderator
collector1231's Avatar
Try resetting the endpoints. It should be in the manual.
Old 09-06-2014, 06:01 PM
DieHarder
DieHarder's Avatar
Low voltage cutoff? Resetting the endpoints is a good tip.
Old 09-08-2014, 08:15 AM
EXT2Rob
EXT2Rob's Avatar
A flashing light is trying to tell you something. Get the manual out, look up "calibrating throttle range on ESC", it should be one of the very first things you have to do.
The purpose of this is to let the ESC learn the throttle range of your transmitter, and is very important to do. Be sure to center all trims on the radio first! Find the instructions in the manual and perform the cal procedure. Once done, and you turn off the ESC and turn it back on again, the only light the ESC should give you is when you give it throttle. If after doing the cal, you still get a flashing light, then something is wrong, probably with the ESC.
Is this a brand new car? Brand new electronics? Or did you supply your own? Maybe a problem with the receiver? Make sure the steering servo is plugged into receiver Ch.1 and ESC/throttle is plugged into Ch.2. You also might try UN-plugging the servo, see if you then get throttle. If you do, then the servo is bad, and "browning-out" the ESC.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
