RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
rustler vxl on 3s heating issues.. solved?
Old 03-27-2016, 08:24 AM
shadowsndust
Default rustler vxl on 3s heating issues.. solved?
So my rustler get hot as balls when running a 3s and of course there's no way to put a fan or heat sink on a 2wd without replacing the transmission housing (then sacrifice the wheelie bar) so I put this blower fan on i found on amazon, in the process of cutting a heat sink to fit, what do you guys think?
Old 03-27-2016, 08:33 AM
shadowsndust
Old 03-27-2016, 12:57 PM
EXT2Rob
EXT2Rob's Avatar
Clever. But the proper way to do it, would have been to gear down a couple teeth on the pinion. 😇
Old 03-27-2016, 02:17 PM
shadowsndust
Yeah I know, i just didt want to sacrifice any top end speed with a smaller pinion
Old 03-27-2016, 02:42 PM
flyinwalenda
flyinwalenda's Avatar
I also think you need to raise the ratio. Even with the fan that motor won't last long.
Old 03-27-2016, 05:04 PM
shadowsndust
What do you think? It has a 24t pinion with the factory spur, 19? 21?
Old 03-27-2016, 06:09 PM
RustyUs
RustyUs's Avatar
Should be one of your good friends in a situation like this.
Name:	ir thermometer.JPG
Old 03-29-2016, 08:49 PM
rc18junky
rc18junky's Avatar
18 or 19 would be best ! It will take top speed away but run way cooler
