RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
New ESC for E-Revo
Old 04-10-2016, 12:59 PM
CalebTheRCguy
Default New ESC for E-Revo
I have a old E-Revo with the dual brushed. The ESC it has doesn't have a lipo cutoff so I can't use any of my batteries with it. I was thinking about using 2 Hobbywing 1080s to run each independently and threw a Y-connector to the receiver. This is for the fact that I don't have much money to do this. Is this a good idea? Should I just hook up each battery independently or solder together the battery wires? If so would I solder them together in series or parrallel? thanks
Old 04-10-2016, 02:38 PM
collector1231
Moderator
collector1231's Avatar
It does not need LiPO cutoff to run LiPOs. Just buy a low voltage alarm and once it starts beeping, the battery is ready to be cut off. A cheap solution, not even $4.
http://www.ebay.com/itm/1-8S-2in1-RC...IAAOSwv-NWWBh2
Old 04-10-2016, 07:57 PM
Maj_Overdrive
Maj_Overdrive's Avatar
Collector has obviously posted the cheapest option. But if you still want to switch to an esc with lipo cutoff the newer Traxxas EVX-2 has lipo cutoff.
I'm not familiar with the Hobbywing 1080 esc and Google wasnt much help in finding it. If you were to run 2 separate esc's they need to be capable of 14.8-16.8v because that's what the stock motors run on. The EVX esc makes a series connection inside the esc. So any replacement esc (whether it's one or two esc's) must be capable of the same voltage otherwise the truck is going to be a lot slower if the motors were running on half the voltage.
Old 04-11-2016, 03:27 PM
CalebTheRCguy
Thanks, now I've noticed the magnitude of my stupidity
Old 04-11-2016, 05:39 PM
collector1231
Moderator
Its not stupidity! You're learning, and its best to learn than be stupid making those silly mistakes, lol.
