Tamiya Hornet questions.
Hi All,
I bought a Tamiya hornet xb for my son last xmas.
We have been through 1 set of tires on the rear and well.
I think they suck they go bald in minutes.
Where we drive is sandy and the car just slip about if you full throttle it. I.e. donuts
I upgraded the stock motor to the sport tuned one. Wasn`t much faster but seems to not make a dent on battery. so was happy for that since the motor is cheap.
So i want to upgrade the front and back wheels. I bought the 12mm hex adapter for about $5. But cannot understand the tires etc.
Can some one suggest a good wheel/rim combo.
doesn`t need to look cool just do the job of holding a tire and the tire works well and last a decent time on sandy dirt areas.
Am i right in assuming any wheel will fit front without adapter? I only need for back right?
Also My son was driving and hit some uneven asphalt the car did a massive jump up and flew about 3m landed and broke the under plastic Triangle shape that holds the wheels on and bent the metal to the servo.
I replaced the under plastic part. But am unsure on the servo part which turns the front tires. For now i bent it mostly back into shape but the servo plastic part holding to metal is cracked and i fear another bump will break it and/or bend the metal again.
Is there a part I can buy to replace those or do i just need to buy a new servo?
Thanks for any help
Thanks for any help
...So i want to upgrade the front and back wheels. I bought the 12mm hex adapter for about $5. But cannot understand the tires etc.
Am i right in assuming any wheel will fit front without adapter? I only need for back right?...
The Hornet's front wheels use bearings last time I looked. If you want to change wheels, you will need wheels that use bearings of the same size, or use adapter.
I'd check out the Rising Fighter's setup for ideas.
...Also My son was driving and hit some uneven asphalt the car did a massive jump up and flew about 3m landed and broke the under plastic Triangle shape that holds the wheels on and bent the metal to the servo.
Thanks for any help
Thanks for any help
