RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
What fan for a Tekno EB410?
Old 06-18-2020, 07:20 AM
Clodbusterfan
Default What fan for a Tekno EB410?
What fan should I buy for my EB410 if I have this option:
https://www.amazon.com/dp/B079V9G9BS/?&tag=teknorc-20 https://www.amazon.com/dp/B079V9G9BS/?&tag=teknorc-20
Old 06-18-2020, 04:23 PM
bill_delong
bill_delong's Avatar
I highly recommend this one, it will be at least 20 cooler than anything else on the market:
https://arndtcraft.com/collections/k...n-shroud-mount
I also recommend a fan with an aluminum case, never damaged any of these either:
https://www.amainhobbies.com/yeah-ra...0472bk/p529891
Old 06-18-2020, 06:10 PM
Clodbusterfan
Thanks bill!
Old 06-18-2020, 08:02 PM
Clodbusterfan
Should I do this fan mount instead thats made by Tekno?:
Old 06-18-2020, 10:36 PM
Clodbusterfan
The ESC/motor combo I want has 2 rx plugs. Do I need this rx if I run the fan on the esc and the fan for the motor on my eb410 I am building? Here is the rx:
https://www.amainhobbies.com/spektru...msr515/p865858
And here is the ESC/motor combo I will be buying. Look at the 2 rx plugs!
https://www.amainhobbies.com/castle-...123-02/p618580
Old 06-19-2020, 04:52 AM
bill_delong
No that is junk, it won't cool your motor nearly as well as the fan mount that I linked above, been there done that!
Old 06-19-2020, 04:54 AM
bill_delong
Your Rx has 5 ports
Ch1 --> Servo
Ch2 --> ESC
Ch3 --> ESC Fan
Ch4 --> Motor Fan
Ch5 --> Transponder
Old 06-19-2020, 07:05 AM
Clodbusterfan
So should I just go with the 5ch rx then?
Old 06-19-2020, 07:41 AM
bill_delong
I was under the impression that you already had that Rx, you can also use a Y-harness to draw power from the BEC if your exsting Rx doesn't have enough ports:
https://www.amainhobbies.com/parkzon...pkz1063/p21260
Old 06-19-2020, 01:53 PM
Clodbusterfan
What do you mean draw the power from the BEC with a y harness? I could use a 3ch rx with a y harness instead of that 5ch one.
Old 06-19-2020, 03:55 PM
bill_delong
correct
Old 06-19-2020, 05:40 PM
Clodbusterfan
Someone recommended this esc/motor combo for my eb410: I have no clue what to do!
https://www.hobbywingdirect.com/coll...14797108478067
Old 06-20-2020, 06:39 AM
bill_delong
Are you racing at a club or just bashing around in your back yard/park?
Old 06-20-2020, 08:10 AM
Clodbusterfan
bill: Just bashing around.
Old 06-21-2020, 08:05 AM
bill_delong
For general bashing around, I would go with a waterproof sensorless setup, they will be far more durable and last considerably longer.
I would get the EZRUN MAX10 3652-4000KV Combo here for speeds in the 35-45mph range:
https://www.hobbywingdirect.com/prod...nt=27757683921
Get the 5400KV motor if you want speeds in the 45-55mph range, where the faster the speed, the more quickly you will drain your battery.
Note that these combos come with a 21T pinion (48P) which should be a good start for your gearing, no matter what, be sure to use temp gun as well:
What gearing for upgraded electronics?
Old 06-21-2020, 03:40 PM
Clodbusterfan
What if I want slower than 35-45mph? Should I get the 3400KV?
Old 06-22-2020, 04:58 AM
bill_delong
precisely, or you could turn down the EPA to your liking
Old 06-22-2020, 07:05 AM
Clodbusterfan
Whats the EPA?
Old 06-22-2020, 07:20 AM
bill_delong
EPA = End Point Adjustment, this controls the travel on the radio, very important to set the EPA on your steering servo so you don't have excess bind which can cause brown outs on the BEC or possibly burn up the servo motor
After you calibrate the ESC, you can also use the EPA to limit the travel on the throttle to reduce top end speed, look for EPA in the manual that came with your radio.
Old 06-22-2020, 07:37 AM
bill_delong
Be sure to read all the manuals that come with your electronics, here are some videos to help give you a big picture to understand these terms:
Old 06-22-2020, 12:58 PM
Clodbusterfan
Thanks bill!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
