RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Baja Rey Center Diff Help
Old 11-08-2022, 01:31 PM
Strap
Question Baja Rey Center Diff Help
Hey guys I'm new to the forum. I need help taking out the center diff from the baja rey. I'm not sure how to disconnect the rear driveshaft from the diff. Any help would be appreciated I'm trying to get into the hobby and do my own repairs. Thanks in advance!
Old 11-08-2022, 05:16 PM
suburban_hooligan
suburban_hooligan's Avatar
iv never worked on one of these, but im guessing the U joint is held on to the output shaft with a set screw. that's probably loctited. a little heat should loosen it up (you can focus heat by holding a soldering iron on the screw) remove the screw and the U joint/driveshaft will slide off.
