Subaru Impreza WRC 1/10 Bycmo
#1629
RE: Subaru Impreza WRC 1/10 Bycmo
Yeah I know makes me laugh everytime I look at the photos
It keeps the tires off the floor stops them from getting flat spots
#1631
http://www.youtube.com/watch?feature...&v=XaMoXRarTno
Hi, Dust,
What i mean is that i don't like to speed up and then loose control and skid without control.
We are trying to set up cars for offroad rallyes.
Hi, Dust,
#1632
some pics of my two cars:
I`ve cutted the electronic chassis and installed receiver and esc inside the tray. And the other car's tray, is the cover
I hope it won`t get too hot.
And for the other car, the holder of the motor is raised so that batteries can be located just down the motor. I hope it`s a better weights configuration let`s see this weekend.
The tray is a common lunchbox... not yet finished.
#1633
First test, one diff. broken ¿are you using bycmo differential? it's good for nothing... Please, advice me which one can i use...
Should I tight it or loose it, for ground driving?
My favourite pilot
sealing high performance system
#1634
hi profesor
i think it could be the bycmo tires your using there not very for grip
also it looks like your running your car on astroturf
as for the diffs i see your using the standard gears black ones
the diff that came as standard is not a very good one its to weak
if you can get hold of the white gears and the upgraded diffs as they are stronger
#1635
have a look at the link
http://www.ebay.co.uk/itm/Deagostini...item35c4b4affa
#1636
Thanks! Someone adviced me to use a Turnigy diff., compatible, but i cannot find it.
I have first fix mine, using some washers, and it looks like working again, but haven't test it already.
I'll keep you updated with my news.
Probably, i'll get this white diff.
#1637
Ok, one friend of mine, has just desisted of working with the bycmo, impossible task, he says.
He adviced me to install this gearbox, instead of the original one.
http://www.rcmitico.es/repuestoshsp/...oscompleta.php
Maybe I'll give it a chance.
#1639
yeah ian you missed a lot not been around for a while lol
prof is using the old gears so i thinking he has the old diff like most of the cars for sale now
people just couldnt wait for the upgrades so ran with the rubbish stuff then bi-tch-ed and moaned when they broke
#1640
Yeah but just lock the crap diff inside.
Will give better grip locked anyway.
How you doing anyway Dus me old mate?
Not been on for a bit, new hotmail/outlook was putting rcuniverse emails into my junk folder so didn't get any replies from here.
Didn't know anything was crackin on here.
#1641
hi prof
had a look at the transmission you sent the link to
tobe honest i dont see how your going to make it work
as the motor runs left to right and the transmission runs front to back
#1645
He's fine, we still play with the cars, not used the Bycmos for a couple of months though, probably just after Christmas.
Not used the 4x4 cars for about the same.
The ones we did brushless conversions on.
We have used the lipo batteries several times.
Had to gear down the HSP cars because they were overheating very fast.
Now we have geared them better they aren't getting hot at all.
#1646
Hi Ian, well, I could lock the diff, but i like "hard" diffs, not 100% locked but let's say 75% ,,, I don't know if i'm explaining. Anyway, if it fails again, i'll stuff it with some putty, blue tack of so.
Regarding this transmission,
someboy else have done it: just screw it in the aluminium chassis, and fix the big teeth wheel on the front axis.
Only thing left is to fix the motos in the chasis so that pinions are conected.
