!!!PROLINE MASHERS 2000 VS. IMEX TRUCK PULLER TIRES!!!
#51
Banned
VA
RE: !!!PROLINE MASHERS 2000 VS. IMEX TRUCK PULLER TIRES!!!
Yes it will smoke through grass. The only thing it will affect is the motor heat and the esc heat. Grass cause's everything to heat up for some reason.
-Wes
-Wes
#53
Banned
VA
yeah, the problem is pulling wheelies and fliping alot. And keeping the front wheels on the ground.
-Wes
-Wes
#54
Banned
ON, CANADA
when i glue my tires 2 the rims.... do i glue the whole edge...or do i dab it on in a couble places?...
#56
Banned
ON, CANADA
yea..... "45mph pede" have u broken anthing on ur pede from jus bashin' around...if u could tell me that would be sweet..... then i would kinda know what i need before any of my parts break
#57
Banned
ON, CANADA
1 more question.... hopefullf u guys can answer it............ will losi xxx-t wheels fit on an evader st....?[&:]
#58
MO
Definitely - I have a ton of 'em premounted so I can change tires quickly. The RC10 wheels fit too. The older ones, or maybe the newest version has a different size axle, so you have to watch for that. I have heard from several people that the offset isn't the same, so the width of the truck changes and ruins your handling and all kinds of stuff. That's not true - the offset is exactly the same as the stock DTX wheels.
#59
Banned
ON, CANADA
sooo..... losi xxx-t wheels will fit?.... i don't need "HEX" hub adpaters?... i can jus' mount my tires and go bashing?...
#61
MO
You won't need hex adapters for the losi or ae wheels. They mount just like the dtx wheels do. Bolt 'em on and bash away!
#62
Banned
ON, CANADA
Crap..................... thanx 4 the help u guys........ really!!....RCU IS GREAT....
"SORRY 45 MPH PEDE" i gotta steal ur pic! [img][/img]
#63
Banned
VA
Hey just realized I punked u and didnt answer alot of your questions. Yes I had to gear up to get 45mph. Useualy I hit about 30 bashin. Also I havent realy broken any parts... I mean the a-arms are probably going to be the first thing to break if somthing is going to. Then followed by all your gears. Just drive smart and you should be ok. Hehe, drivin smart... But yea, everything should be fine. Good luck,
-Wes
This thread dus rock!
-Wes
#64
Banned
ON, CANADA
hey... about proline masher 2000 tires... i got them 3 dayz ago... and i but them on the rims and but in the foam incerts... and glued the whole edge down on to the rims when the glue i had left... and i was rippin it down the street.... they the ballon like mad!!... like they lift up my evader an extra 2 inches in the back...[&:]... why does it do this?. now when i hit jumps i do uncontrolable flips![:@].. i guess it's kool in-a-way... but i can never land them.... what's the problem?...
#65
Banned
VA
Every off-road tire balloon's. Glueing doent do anything but keep the rims from spinning inside the tires and keep the tires on. It just will take a little getting use to... soo you will be landing tires like mad. Is it a bouncy landing thats the problem, or is it just 'in air flips' thats the problem.
-Wes
-Wes
#67
MO
Let off the gas in the air. The bigger tires spinning at full throttle will spin you nose-up faster than the smaller tires that you're used to. In the same way, if you hit a jump wrong and you're nose-diving, hit the gas, and you'll bring it back up. With practice, you'll get the hang of pointing it in the direction you want it to go.
#68
Banned
VA
Yup, plus... If you dont let off the gas and you get a more modded motor (novak ss) you will snap your center drive line like a tooth pick!
-Wes
-Wes
#70
Banned
VA
Whaaaaaaaaaazuuuup!
Watchin the game havin a bud...
wow I watch to much tv... those were the best though!
-Wes
true... true...
-Wes
#73
MO
got my first when I was 7 or 8 - barely able to call it rc. a gas powered cox dune buggy...
So, that ends up being about a quarter of a century. Scary, huh?
#74
Banned
ON, CANADA
so ur like 15 now right.... i satrted when i was 12 with a traxxas rustler.... now im 19... and i got a evader st!.....lol its kinda funny
#75
MO
I wish... I'm 34
While I'm at it, when I got the ole' cox buggy, I also got a cox powered airplane - demolished the plane before I ever graduated from the trainer cord! That prompted me to stick with the stuff that has wheels.
