RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Soldering difficulty
Old 11-29-2004, 03:09 AM
thecrow2k
Default Soldering difficulty
I am currently running sidebyside stick packs and was rcomended to switch to flat packs so I can equalize, how hard is it to solder battey packs together, I have little soldering experience only soldering together PCB's at school to make things like moisture detectors. How hard would this be?
Old 11-29-2004, 05:16 AM
Dannyhaddon
Dannyhaddon's Avatar
Default RE: Soldering difficulty
youve gotta use atleast a 30w solder iron if your not using this then the solder isnt likely to stick
Old 11-29-2004, 09:31 AM
aliens8mycow
aliens8mycow's Avatar
The hotter the better actually - a 30w iron is probably minimum, and I would expect it to be difficult to get things done with that. A 60w iron or butane iron would be much easier to work with.
Just make sure you flip the batteries opposite directions before you get started so you get + connected to - down the pack. You can get battery building jigs for $10 or so, which will hold them while you solder. Just as easy, you can get some shoe goo and put a bit between each cell and then let them sit overnight before you solder anything. Then you can stand them on end and solder away.
Old 11-29-2004, 09:43 AM
someoneelse
someoneelse's Avatar
What they said sounds accurate to me, but make sure to use some flux on all of the contact points, it will make your life easier
Old 11-29-2004, 11:13 AM
muahaha
u might want to pick up a dean's battery jig to make life simple for u. iron choice, i prefer to use an 80watt iron, less time the iron has on the battery the better. especially with nimh batts.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
