Can I Use a Remote That Uses Sticks?
TX
I know it seems crazy but i would rather have a remote that uses sticks. I used to have a Nikko and i like that remote. If you know of any remotes that uses sticks and that would work good with a rising storm lmk thanks.
Banned
RE: Can I Use a Remote That Uses Sticks?
There is some uber famous racer that uses a stick version of the Airtronics M8. He, like you, grew up on the sticks and never got used to a pistol. I have no idea who, or what model, but Airtronics is probably a good place to start. Since it's based on the M8, expect it to cost an arm, a leg, a lung and probably a kidney.
ON, CANADA
There are many made by futaba and other companies that use sticks, most are lower end 2 channel radio's but others that are made for boats are more, 3channels+ and people also use airplane radios that are converted for surface use eg. 75mhz rather then 72mhz.
there are many options.
I used to like the sicks but now have gotten used to the pistol grip and like it much better then the sticks try one out
Nick
Nick
TX
ok thanks alot for the info i didnt know if it was possible i saw that they were available for boats and airplanes
MD
I just bash, I don't get to race, and I enjoy using both kinds of radios. I'm comfortable driving sticks and pistols equally well. There's just something fun about using a 2-stick once in awhile. I have cheap Futaba 2VR's and T2DR's. They are hella inexpensive and work great, never a glitch! I normally use my 2-sticks for my electric monster trucks and drive my cars with pistols, I mix it up some times though. One thing I really like is that I use a tower hobbies neck strap with my 2 sticks and that takes alot of fatigue out of long runtimes. My clod crawler runs like 45 minutes with GP3300's, hehe.
The pistols generally have alot more features in the same priuce range though..... my 2pl pistol has digital trims, dual rate, and 10 model memory. The am 2 sticks are very basic. trims, servo reverse, some have a charging jack, some will let you modify them for 70/30 throttle travel instead of 50/50. 2-sticks seem to be available two ways hella cheap and basic 2 channel, and hella expensive 4 channel and up. You can buy many of the 4-channel airplane radios in a ground frequency.
Really I think that anything that I have that goes really fast and needs precise control, I like the pistols, but the 2-stick is definatly a blast to fool with once in awhile.
ON, CANADA
Oh yeah, I remember that sticks version of the M8!! that thing looked like something NASA was fiddling around with! With that LCD screen at the bottom... that was lush! Doesn't Lamberto Collari (1/8 on-road) still use sticks?
IN
2 sticks is quite common in Europe, from what i can tell from all the race videos i own. A number 1/8th on road and off road drivers use them
ON, CANADA
ORIGINAL: Speedmunkey
That's the guy I was talking about.
