Can you help ID this Pan Chassis?
Hi All,
Just got this old abused Pan car chassis and I am trying to identify it. I was told by the fello whom I got it from it is a Bolink. However the car Guru at my LHS says it is not a Bolink but he could not remember whom made it. So is it a Bolink or not?
Thanks!
Pics here:
http://www2.twmaster.com/boats/lumchassis1.JPG
http://www2.twmaster.com/boats/lumchassis2.JPG
Thanks!
Pics here:
Looks like a Composite Craft Lynx II from the early 90's. Fast cars for the time and ability to tune wheelbase could realy dial you into a track, or let you dial yourself right out of the race. The pivot ball between the rear pod and main chassis would develope a lot of up and down slack quickly. They offered a couple different front end beams that allows camber adjustment. Beam is split in the middle allowing different caster on each wheel. Always fun if it got a little loose and started self adjusting during a race.
Hope this helps.
Ed M.
Hope this helps.
Ed M.
GA
well i am not sure if that is a lynx II it possibly may be without the graphite chassis kause i have one and this thing moves let me know if you have any questions
http://www.rcuniverse.com/showthread...250&forumid=42]
This is a Lynx. After looking at your pics I am sure this is a Lynx. The only difference I could spot was the chassis it's self. I was told there were a couple of different chassis plates available when the car was current.
Thanks for the pics
Thanks for the pics
GA
yeah i know they made a couple of differnet versions i mean i know that this was the full race modified one with the graphite chassis kause it used to be raced for the local hobby shop
