Xray T2
PA
Xray T2
Hey all, just got my T2 together and on the track... close to 2 second faster lap times then my older car...
Anyway, I wanted to see if there were any other's out there using it. I have a few minor concerns with it but I wanted to see what you all thought...
1. When using Jaco foams on the front the wheels rub not only the rear of the hubs but also the front springs... I shimed it out 1.5 mm and set my EPA's accordingly but I loose a bit of steering. To compansate I started using mre Traction Compound on the front butthat wares off about 20 laps in...
Any other's with sugestions??? Will I loose a lot of traction switching to a narrower tire? Thanks, G.
2. It's tough to find the proper spurs to use. Most are too thick and will rub on the chassis.
3. the top deck doesn't have countersunk screw holes... But other then that, it's top notch... Easy to work on and get to the basics...
PA
RE: Xray T2
Anyone???
Well, I moved the front shocks to the inside on the bottom and that gave me about 15* more steering. Still have to shim them though. Thanks, G.
PA
RE: Xray T2
Lots of changes from the FK05... Let me know when you get it and have it out for a few laps...
It's a heck ofa car but there are some stupid things on it like the wheel thing that bug me... Thanks, G.
