13t ESC with dual motors ?t
My Feedback: (-1)
PA
I just found an old ESC in my toolbox and I want to use it in a Clod that I'm building next month. It is rated at 13t with a current rating of 180 continuous. I know it will handle a pair of 55t lathe motors but I also want to be able to drop in a faster pair of motors for playing around in the back yard. How low can I go in parallel? in series? Also, is there a way to disable the BEC so that I can run a 6v pack ( the ESC only puts out 5v ).
RE: 13t ESC with dual motors ?t
you can disable the bec, but it could be tricky and a bit dangerous [depends on the setup sequence of the esc]. you may use dual 27t for sure, and with 180amps continious, means that you can go as low as 21t [really depends on the motor specs].
OR
ORIGINAL: kostaktinos_mt
Of course, if you've got a different ESC, that may not be entirely correct.
-K
IN
would a tekin tcs g-12 handle 2 19 turn or 16 turn motors wired in parrallel? I am also needing this for my racing clod I have this esc and it has no turn limit on a single motor so am I right it will handle two 16 or 19 turn motors? Please help I will be racing and bashing this clod I built an all alloy chassis and it has a 16" wheelbase. I will also be running a 4 rear stampede shocks.
