Super Clod Buster Build-up Thread
#2001
RE: Super Clod Buster Build-up Thread
time for me to build my stock CLOD...timee 00.13 AM here...so...pics with the finised products...soon...I hope...
already give up...too much jach d arround ....[&o]
#2002
PA
ORIGINAL: cornel4web
#2010
sorry for no pics for now...finished the clod...run it in the house...a little disappointed. very poor steering capabilities...do I need to start modding it...do I really need 2 servo for 4WS?[][][][X(][X(][X(]
#2011
PA
Yea the stock Clod has really bad steering especially when you're trying to drive it in a confined space. To get the best steering you'll either need dual axle mounted servos or a single high torque servo with an aftermarket servo saver so that you can lock down the stock servo savers.
#2012
what motor config for popping wheelie with the monster? serial or parallel setup? Can handle the Tamiya ESC TEU-101 BK that config?
#2013
CA
i was able to pop wheelies with a 101bk with stock silver motor and a 6cell pack.
if you want crazyiness the run the thing on 12 cells
#2015
CA
it was easier to do it in parallel mode, in series it ran out of steam to quickly to really lift the front wheels
#2016
running in parallel will give you more power. series will give you more run time. i run mine parallel. i didn't try series, but i can't imagine how boring it would be. the thing isn't slow, but it doesn't have room to lose any performance. it will try to pop a wheelie...but doesn't get more than an inch off the ground.
i would not use the teu-101bk for 2 motors! that thing is made for one. and i certainly wouldn't use more than 6 cells, either. i mean, if you don't care if you burn it up, then you might just see how long it'll last. but i wouldn't.
let's see some pics...surely the hangover is gone by now
#2017
Tamiya is releasing this for their dual motor setup!
http://www.tamiyausa.com/product/ite...oduct-id=45037
#2018
I'm using this ESC: Novak, XRS sport reversible
http://www2.towerhobbies.com/cgi-bin...&I=LXGNG5&P=ML
was easy to mount in series...but tonight I will solder the wire for a parallel setup...I know this is better, I already use parallel for my SPIDER...
got to solve somehow the steering weaknesses ...[:-][:-][:-]
#2021
http://www.teamnovak.com/download/in...erduty_ins.pdf
no need to solder anything extra for parallel. look at the pics. this is what i did for running parallel on mine. i use the novak super duty, though.
i don't know if that XRS can run 2 motors?
#2022
I run my super duty in SPIDER...and no problem for that to handle parallel...
but for clod, XRS is what I have...[:-][:-][:-]
#2023
Find out and let us know...
It will probably do okay w/ dual silvercan.. but barely...
do you think it won't handle it?[X(][X(]
is rated at 40A...[:-][:-][:-]
#2024
if you can't/don't want to shell out the bucks for the super duty, i would suggest the stock esc out of either the e-savage or e-maxx. the one for the e-savage can be had for about $50-$60 if you watch the auctions on ebay. most people will ship worldwide, too. just a thought.
i really predict failure for the XRS. but i will qualify that by saying i've never used one. but based on teh fact it's made for a single motor, i think it would burn up.
